Quote:
Originally Posted by mudtire08
My trans oil started to disappear and I couldnt find the leak. After a while looking on here i found out that the seal leaks bettween your transfer case and transmission. My transfer case was about half a gallon overfull. Check your transfer case when it is cold and see if it is overfull. It cost me about 170.00 to get it fixed if that is what it is. Hope this helps
hi there yes after we removed the trans case mount crossmember today and pulled the pan off the tranny we now see that it is coming from the gasket between the trans tail and the case adapter wow...
what bad deal...
why is this gasket leaking ?
poor design gasket or what ?
how do you check the levle in thse transfer cases btw ?
and what mode is it with 4r70W and 4.6L 1997?
the dealer here was unable to look up this gasket and instead gave me the big round shaped one at the front of the transfer case
idiots..
totally useless dealership we have here..
lousy!
where are the bolts hidden for the adapter to the tranny tail end anyways ?
we only see about three of them in the lower part of the adapter ?
small 10mm head ones
there are holes in the upper part that should be bolts but there are none
are they inside the adpater or something ??
thanks
