F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-11-2009, 12:13 PM
trans change
I WAS WONDERING IF YOU CAN CHANGE THE TAILSHAFT FROM A 1994 4 wheel DRIVE 5SPEED TO 2 WHEEL DRIVE 5 SPEED AND IT WORK. I WAS TOLD THAT IT COULD BE DONE. I HAVE ACCESS TO A 2 WHEEL DIRVE BUT DON'T KNOW IF IT IS POSSIBLE, LIKE TO HEAR FROM SOMEONE THAT KNOWS. THANKS
Old 03-12-2009, 11:31 AM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
No. The extension housing on the 4x4 transmission is actually an adapter which allows you to bolt the transfer case to the transmission. Do you mean to try and use the extension housing from a M5OD-R2 two wheel drive transmission on BW-4406 transfer case?
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 03-12-2009, 03:11 PM
i have the original transmission and was wondering if i can change the rear adapter off of the 4x4 to the 4x2 transmission so it will bolt to the transfer case. are the shafts the same ?
Old 03-12-2009, 05:03 PM
JMC JMC is offline
Your statement is ambiguous.
On a 4x4 drive train; After the engine comes the 4x4 transmission (4A) then the extension housing/adapter(4B). The Transfer case(4C) bolts to the transmission extension housing/adapter (4B). On the driveshaft end of the transfer case is the extension housing(4D). The driveshaft slip yoke(4E) slides into the transfer case extension housing(4D).
On a 4x2 drivetrain; the transfer case is eliminated. The 4x2 transmission(2A) is bolted to the engine block and the transmission extension housing(2B) is bolted to the transmission. The driveshaft slip yoke (2C) slides into the transmission extension housing(2B).
If I understand you correctly want to install the 4x2 transmission extension housing(2B) onto the transfer case (4C) in place of the transfer case extension housing (4D).
Regards
Jean Marc Chartier
Old 03-12-2009, 08:10 PM
what i need to know is if the extension housing -adapter off of my 4x4 transmission will fit a 2 wheel drive transmission. i am also wondering if the tail shafts are the same or if they have different splines. i have access to a two wheel drive transmission that i am wondering if i can use with the 4 wheel drive housing -adapter to mate to my transfer-case. i understand that i have to remove the 2 wheel drive extension housing and bolt the 4 wheel housing in its place. i am wondering if it possible to do this before i purchase the transmission. thank you for your help
Old 03-13-2009, 05:25 AM
JMC JMC is offline
OK, you cannot use the 4x2 transmission in place of the 4x4 transmission. The output shaft on the 4x4 transmission is shorter to accommodate the 4x4 adapter. You would have to disassemble the transmissions and swap the output shafts.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
