F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-08-2009, 06:07 PM
Vehicle: 2006 ford F150
tranny fluid change
can anyone give me a how to on a tranny fluid change and flush for my 2006 xlt 5.4 i have 60000 bought it at 30000 not sure if it was done ford told me to wait till 65000 im pretty good with all ths stuff but i just wanted to see if there was a how to or something so i could get a look at first
thanks
Old 03-08-2009, 06:58 PM
Vehicle: 2003 Ford F-150
If you want a flush done, you aren't doing it unless you have that power flusher machine to do it with.
Since my F150 is my first auto trans I have owned, I let it go a little too long and got the TC shudder.
No problem, it was time for a flush. Shifts much better and the filter does not need to be changed as that machine does the job.
2004 XL Sport SuperCab 4.2L/Auto
Factory forgot fog lights, switch and valance...finished their job for them.
Old 03-08-2009, 11:47 PM
Vehicle: 2007 Ford F150
Changing ATF Fluid in a E4OD and 4R100 transmission
By Mark Kovalsky
I've done this alone. It's easier with a second person, and sometimes helps prevent spills.
1. Things you need to get started:
1. The E4OD and 4R100 transmission system holds almost 18 quarts of ATF, and you must waste a couple of quarts to be sure you get it all purged and replaced, so buy 20 quarts of MERCON ATF [do NOT buy MERCON V!]. Ford also warns against using a fluid that has a dual MERCON and MERCON V rating.� You may use either conventional or synthetic, as long as it meets the above requirements.
The 4R70W transmission system holds about 14 quarts of ATF.� The 4R70W uses MERCON V, and the MERCON V can be used on older 4R70W transmissions that were factory filled with MERCON.
2. I replace the transmission filter every other fluid change. Note that Ford does not recommend ever changing the filter. I've opened filters with over 300,000 miles that were not even close to being clogged.�
3. Don't buy a new pan gasket. The original is reusable.
4. A 10 foot length of clear tubing and one hose clamp, sized to fit over your cooler hose. There have been different size cooler lines over the years, so check before buying!
5. If you don't already have a special funnel that fits into the transmission dipstick tube, then you will need one of those, too.
2. If you are changing the filter, drain the pan if your pan has a drain plug. If you are not changing the filter, jump to step 4.
1. If you don't have a drain plug, go to step 4 to pump out the pan, preventing an ATF shower! Return here after step 4 and one pass through step 5a.
2. Remove the pan and clean the pan and gasket, including the magnet on the bottom of the pan. Fuzz on the magnet is normal, that's why it is there!
3. Change the filter. It just pulls out, there are no bolts that hold it. It is held in place by the pan. Make sure that the O-ring is removed, too. Sometimes it does not come out with the filter.
4. Replace the pan, using the reusable gasket.
5. At this point you can drain the torque converter. Some people think it is necessary, but I don't. Running the engine in the next steps will pump the fluid out of the torque converter.� If your transmission was built after August 2001, you don't have a drain plug in the torque converter.�
6. To drain the torque converter remove the shield (or the rubber plug in some models) and turn the flywheel until you see the drain plug. If you also drain the torque converter, then the old ATF will not come out the return line until after the torque converter has filled.
3. If you drained the pan, pour new ATF into the filler [dipstick] tube until you have added about as much as you earlier drained from the pan. At this point overfilling by no more than one quart won't hurt anything.
4. Disconnect the transmission-fluid return line at the transmission - from where the ATF returns to the transmission from the cooler. This is the line towards the rear of the transmission. Clamp the clear tubing over the line that you removed from the transmission. This is where the fluid comes out.
5. This is where the second person comes in handy. One person starts the engine, while the other holds the line over the drain bucket.� A clothes pin can replace the person holding the line in the bucket.
1. Run the engine until you see some air in the clear tubing.� As soon as you see air shut off the engine. Refill through the dipstick tube with the same amount as you just pumped out.�
NOTE: If you drained the pan and the torque converter, fluid will not run out until you fill the pan a second time. Run the engine for 30 seconds, then stop and add six more quarts.
6. Repeat step 5 until you have added 19 quarts with of new ATF to the system with an E4OD or 4R100.� Repeat until you have added 13 quarts with the 4R70W.
1. At least one time while the engine is running move the shifter through each position from P to 1, pausing about 5 seconds at each position. This will change some fluid that would otherwise be trapped in the valve body, accumulators, and clutches.
7. Remove the clear line and reconnect the cooler line to the transmission.
8. Check the fluid level and use the last quart to top off.
9. Properly dispose of the used transmission fluid.
10. Congratulate yourself! And your engine starter/killer person.
Old 03-08-2009, 11:50 PM
Vehicle: 2002 Ford E350
Hey! I recognize that article. Excellent article, written by a great guy!!!!
It does need a bit of updating. MERCON has been replaced by MERCON V. MERCON V has been changed to make it compatible with older transmissions that used to use MERCON.
Old 03-08-2009, 11:52 PM
Who was that masked man?
Old 03-09-2009, 12:53 AM
i was told that i should use royal purple what trans fluid do yall recommend?
NEW PIC SOON TO COME
6 inch superlift-icon adjustable coilover-cutom leafspring rear-troyer tune-troyer pulleys-troyer e-fans-custom offroad exhuast-air aid cia-metal moto 958-BFG Goodrich KM2 35x12.5x17-yukon 4.88 gear-performance slotted and dimpled rotors-westin grille guard-4 hella rallye 4000- pioneer avic 700bt
Old 03-09-2009, 01:34 AM
I've used Mobil 1, Red Line, Royal Purple, Lucas Oil, and Motorcraft. All have worked fine. Just make sure that whatever you use meets Mercon V specs.
Old 03-10-2009, 01:20 PM
Vehicle: 2008 Ford F-150
Is the title of the article posted above really for the 4R70W tranny also. The title threw me for a loop there,(E4OD and 4R100) I am a FORMER chevy guy, still learning all the Ford components.
Old 03-10-2009, 01:48 PM
The above described process will work on just about any automatic transmission. You are simply disconnecting the return line so that the old fluid does not go back into the transmission, and replacing that with new fluid.
Old 03-10-2009, 02:10 PM
The title was a mistake. It was supposed to have 4R70W in the title, too, but I screwed up.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
