F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-08-2009, 10:31 AM
Question F150 clutch question
I have a 1994 f150 4x4 that i bought with a clutch problem. The peddle has pressure but the truck will not move. It makes no noise as in grinding or ratteling can the clutch be totally burned out or is it something else?
Old 03-08-2009, 03:34 PM
Vehicle: 1994 Ford F150
Are sure that your transfer case isn't in neutral?
trying to master the modern automobile,(truck too of course) good luck to me.
Old 03-08-2009, 03:40 PM
Vehicle: 2005 Ford F150
Sounds as if it is in the tranny not the clutch. With the engine off, you should be able to shift into neutral and move the truck, even if the clucth is frozen. The clutch disk can freeze to the pressure plate and you can't shift with the engine running, but can with it off.
Flowmaster 40, K&N dropin, Tint, Roush wheels, 305/50/20s
Edge Evo with PHP custom tunes, GF 2" shackles
Old 03-08-2009, 06:54 PM
I can put the truck in gear with it running or off. I pulled the driveshafts out and put the transfer case in gear and both yokes will turn as if it is in gear but don't know if the transmisson is turning. It sound like the trans is turning inside but don't know how to check if the clutch is or not. I was told that maybe the center was broke out of the clutch. I am stumped should i pull the trans ?
Old 03-09-2009, 11:36 PM
Pulled trans today clutch is in great condition. I guess it is trans or transfer case time..
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
