Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 02-09-2009, 06:56 PM
Garage is empty, add now
Can't Shift Out Of PARK
'98 F-150, 5.4L, 4-speed automatic + OD. 120k miles.
I've searched the forums but haven't found an answer.
A few weeks ago, I fired up & tried to shift out of park - wouldn't budge. Finally, while pumping the brakes and 'jiggling' the key, it shifted out of park and I kinda let it go. Several days went by & no repeat of the problem. Now for the last few days, it's been happening again. Doesn't seem to matter if it's cold or warmed-up, parked flat or on a slight incline. Ambient temperatures (Seattle area) haven't been too extreme (and this pickup 'grew up' in northern Canada) - 25 to 55 degrees Fahrenheit. Fluid looks clean, doesn't leak and I keep fluids maintained at the proper level.
Any known issues that might cause this?
Anybody have or had similar issues?
Thanx for any input!
Old 02-10-2009, 07:55 AM
Vehicle: 2001 Ford F150
From the description I would check the brake switch. It sounds like it isn't providing the signal to allow the to shifter unlock.
Darrin
Old 02-10-2009, 08:02 AM
Goat Herder Extraordinaire
1999 Ford F-150
Vehicle: 1999 Ford F150
Safety feature, won't allow you shift out of Park unless you have your foot on the brake.
When the brake switch goes bad, it's telling the shifter not to shift because you don't have your foot on the brake,
even if you are standing on the brake pedal with both feet.
Old 02-10-2009, 01:41 PM
sounds like my problem. The ford tech said check brake lights if they work your switch is fine. don't know if that is correct or not but don't have a lot of choice now. If that isn't it i was told I have to replace my entire shifter mechanism.
Old 02-10-2009, 05:49 PM
Vehicle: 2007 Ford F150
Exclamation
Check the connections to the BOO (brake on/off) switch first! When I had a 97 f150,that what was wrong with mine!
2007 F150XL,4.2V6,3:55 non L/S,auto
Dark Blue Pearl Metallic
The anticipation of death is worse then death itself!
Old 02-10-2009, 06:27 PM
Vehicle: 2001 Ford F250 6.8
Don't forget that this is also a symptom of a blown fuse for the brake lights, usually due to the owner FAILING TO RESPOND TO THEIR RECALL NOTICE!!!!
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX - Gone
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L - Gone
1998 Ford Contour Wifey's old daily driver, now mine.
2007 Mercury Mariner AWD - Wifey's newdaily driver
Old 02-11-2009, 02:08 AM
THANK YOU!!! for all of the (correct) responses
The brake light switch was bad! Fuses checked out OK but brake lights weren't working. So.....I replaced the switch and voila - problem gone!
I was amazed - it was a 5-minute job even for an automotive klutz like me.
I really appreciate the input you all provided - I can almost build a PC from 3 paperclips, a disassembled ball-point pen and 2 AA batteries but don't do much "hands-on" with the vehicles (except for replacing oil, filters, bulbs & fuses stuff).
'98 F-150...................the workhorse
'96 Windstar...............grandchild hauler (& loaner when the kids need it)
'07 Mitsubishi Spyder....my daily drive
08 Nissan Altima..........wife's daily drive
Old 02-11-2009, 07:29 AM
1999 Ford F-150
I see you have a Windstar.
I had a '95 and that is actually where my brake switch went bad.
Luckily, the Windstar was under warranty and Ford wasn't near bankruptcy a dozen years ago because I snapped that shifter in half and they covered it.
It was dangling in the floorboard hanging by the O/D wire.
The Windstar and F-150 have the same shifter handle. It's steel but it's hollow and when an idiot like me thinks it just stuck.....:o
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
