01-12-2009, 11:29 AM
Intermittent O/D Problem?
Hi, I have a 1997 F-150 supercab with a 4.6L engine, 4WD and 256K miles.
Since i've had the truck ( about a week) It has had a delay going into first (which after reading around today, I'm suspecting is the fluid and filter needing to be changed)
But the o/d is another story. On a trip to harrisburg, i noticed that while cruising in o/d, It will randomly jump into what seems like neutral for a second, rev up since my foot is on the gas, then return to o/d and be fine. no clunk or thump... its all nice ans smooth.
It doesn't have a preference as to when it does it either (under load, cruising, uphill, downhill, etc.) it will just do it randomly, and go back to o/d... when it locks back into gear, I can resume driving as i was...put my foot on the gas and it will go fine. sometimes, it wont do it at all. No codes, no blinking light, nothing... fine in every other gear...
Could this be my OD going? or do you guys think a fluid and filter change will do the trick for it as well? Or possibly something electrical?
Thanks in advance!
-Rob
01-12-2009, 11:43 AM
At 256k, your tranny may be on its last legs to begin with. If you want to try a fluid change, drain the torque converter too, it has a plug on a 97.
2003 F-150 XL RCSB 2wd 4.2 M5OD 3.55 LS
01-12-2009, 11:52 AM
2001 Ford F-350
Vehicle: 2001 Ford F-350 SD
i say change fluid and filter also add lucas transmission fix. The tranny fix does work it lubricates the bands better. Trust me it I had the same problem about 12,000 miles ago and it hasnt done it since
ohh my tranny has 354000 miles on it
01-14-2009, 09:22 AM
Ok, changed the fluid and filter, and that fixed my delayed shift problem... And so far, around town, the O/D has not acted up... I will take it on the highway a bit later today, and I'll get back with a result
Thanks!
-Rob
01-14-2009, 11:18 AM
My '97 torque converter is very sensitive to small pedal movements. Takes very little to get it to unlock, and when you get back on the gas, it will rev up and then drop back down as it locks. This is annoying, but normal. Very annoying, I might add.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company |
