It comes out of your trans and runs to the top drivers side of the rad then out the bottom to your external cooler and back to the trans.
A lot of guys put the T in closest to the trans or under the rad. I added mine just before it goes into the top of the rad. I wanted to keep it out of the weather (read road salt). I am guessing that the fluid gets there fast enough to only lose a degree or two.
2003 F150 4x4 FX4 (White): 5.4L, Custom Tuned Gryphon Programmer, DIY Air Intake Mod, Troyer E-fans with DD PAC-2700 Fan Controller, True Duel Straight Pipes with X-Pipe, Factory Tech Separator Plate, F250 SD Trans Cooler, Digital Trans Temp Gauge, Timbren Rear Suspension Enhancement System, Mag-Hytech Rear Diff Cover.
Reason: I can't spell.
