F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 01-08-2009, 02:39 PM
Stripped!!!!!
Seems like i have had some super bad luck lately mechanical wise. My slave cylinder in my 89' f150 shortie regular cab decided to take a dump on me so i decided to pull the motor out and replace it. Well when i went to put the new slave cylinder on the bolt holes to hold the slave cylinder on were stripped! you can thread them all the way in but if you put any stress at all such as barely pulling on the cylinder the bolts will pull right out of the hole! can these holes be tapped? if not does anybody have any ideas on what else i could do to solve this problem? im about to just drop the whole manual transmission and throw in a c4 and stick a hurst shifter threw the floor.
Old 01-08-2009, 02:45 PM
Vehicle: 2003 Ford F150 FX4
Quote:
You should be able to tap them and use a larger diameter bolt or get a helicoil kit and use the same bolts.
Old 01-08-2009, 02:49 PM
Vehicle: 2005 Ford F150
drill them and put a heli-coil kit in it
Old 01-09-2009, 07:44 PM
JMC JMC is online now
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Internal slave, helicoil or insert only. Larger bolts will require enlarging the holes in the plastic slave. You risk destroying a slave cylinder as the bolt holes are bushed with metal so to enlarge the holes you have to remove the bushing and enlarge the hole then find a larger bushing.
External slave, drilling and tapping for a larger bolt may work if there is enough meat on the slave to enlarge the mounting bolt holes.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
