F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 01-08-2009, 01:04 AM
Vehicle: 1998 ford f150 4.6l
Send a message via AIM to kstonelb86
Question transfer case and gears question
Hello its been a while.
the deal is is that i had found a leak around the tranny pan and drove the truck to the shop that did my gears and they say that my transfer case is leaking along with the adapter housing gasket and they will fix it at charge. but i thought that they broke into the transfer case when they did the gears. AAMCO refuses that they did.
is this true or am i out $600?
thank you very much.
1998 f150
4.6l 182,000mi
4x4 off road
single 3.5" tip flowmaster 40s.
285/75/16 dean mud terrain
firestone air springs
Tow- 18' fc titan 4000lbs dry plus two crf450's
http://www.f150online.com/galleries/....cfm?gnum=7830
Old 01-09-2009, 05:09 PM
Vehicle: 2003 Fast Screw
Your out 600 bucks!
To change your gears,,they did not have to touch your tranny or T case!
They only change the gears in your front and rear differential.
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
Old 01-09-2009, 07:33 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Just so you know. The transfer case is sealed at the input end (where it is bolted to the transmission). The transmission is sealed at the output end, extension housing adapter. Ford in their infinite wisdom put a gasket where the t-case bolts to the transmission. Why? I do not know as there is also a drain hole at that joint. So either the transfer case is leaking or the transmission is leaking. Or both.... You have to remove the transfercase to service either leak. There is a couple of hours work just in removal and reinstall.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 01-12-2009, 08:10 PM
thanks you guys.
great info
better put in for that overtime.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
