F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 01-07-2009, 01:33 PM
Vehicle: 2004 Ford F150
Sea Foam Transtune
My 04 has about 59k on it and I was wondering if anyone has ever put seafoam transtune in their transmission
Old 01-08-2009, 01:02 AM
Vehicle: 1999 Ford F-150 5.4
I wouldnt. Just change the fluid. Dont screw around with snake oils. Properly maintained trannys will last 200k. Change the oil every couple of years.
Old 01-10-2009, 11:50 AM
Vehicle: 1997 Ford F150
Talking
Jet
Guess I am an overachiever......My trans has almost 250K on it. Put a shift kit in at 30K, and change the fluid and filter every 30K. Should easily make it to 300K.
Old 01-10-2009, 01:23 PM
Vehicle: 2001 ford 250
dont take any chances with that stuff. regular fluid and filter changes is all u need.
Old 01-10-2009, 04:06 PM
glc glc is offline
Vehicle: 2003 Ford F150
The only time you should put anything except transmission fluid into a transmission is to try to cure a specific issue temporarily (such as seal leaks) until you can do a teardown.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 01-18-2009, 12:09 PM
Vehicle: 2006 Ford F150
The only thing that Transtune probably does is make the clutch packs swell to eliminate any slipping. Add brake fluid would accomplish the same thing pending you put in the correct amount and didn't over do it. Otherwise too much brake fluid and it would eat them away.
blog.hillbillyhardware.net
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
