F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 01-06-2009, 10:45 PM
Vehicle: 1998 Ford F150
Larger tranny cooler??
Anybody with the trailer towing package ever installed a larger cooler, the one that comes with the truck seems allright just kinda small....
If you got any pictures or advice mounting one would sure be appreciated..
Its been on my to-do list for awhile now..
Old 01-06-2009, 10:57 PM
Vehicle: 2003 Fast Screw
I put one like this in my truck! It's about 4+ times bigger then the stock one. Works great.
http://www.dieselsite.com/index.asp?...ROD&ProdID=480
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
Old 01-06-2009, 11:02 PM
Nice Phil !!! Was it hard to do?? Did you add a tranny guage or one of those multiple guage units that watches everything?
Sweet ride also Phil!! Just how many lil hemis have you eaten with that stunning F150 of yours??
Old 01-07-2009, 05:04 AM
Vehicle: 2007 Ford F150
I have the B&M cooler with an electric fan attached, and use a ScanGuage II.
Old 01-07-2009, 05:29 AM
A Mag-Hytec transmission pan helps too.
Old 01-07-2009, 05:46 AM
Quote:
It wasn't bad at all,You have to remove the big grill and it bolts right behind it like it was made for the truck. We took the stock one out and just used the big one and my temps came down about 50*!
And yes,,I have a tranny gauge.
Thanks hemis are no problem,,,but it's a lot more fun killing the stangs..
Phil
DMR Cog belt system
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
Old 01-07-2009, 10:25 PM
Phil
Yea, I can understand, but I just hate Dodge's....That's all that is around here, hemi this hemi that....I had one Dodge and that was one to many, after I fixed her up and painted it, I did make some money on it but that ws it..
I would rather push a Chevy than drive a moreparts (mopar) Dodge of any kind!!
Old 01-07-2009, 10:26 PM
Quote:
Nice one again 50!!
Old 01-08-2009, 02:54 PM
Vehicle: 2003 Ford F150 FX4
Phil
I have this trans cooler but I ordered it from Ford. It is designed from the f250 super duty one if I remember correctly. It also costs less from Ford. It works too well in the winter my temps have not been getting up above 100. In the summer towing my trailer the highest I saw was 185.
2003 F150 4x4 FX4 (White): 5.4L, Custom Tuned Gryphon Programmer, DIY Air Intake Mod, True Duel Straight Pipes With X-Pipe, Factory Tech Separator Plate, F250 SD Trans Cooler, Digital Trans Temp Gauge, Timbren Rear Suspension Enhancement System, Mag-Hytech Rear Diff Cover.
Old 01-08-2009, 07:44 PM
Vehicle: 2001 ford F150
TCI also makes a tranny pan. its cheaper than the maghytec.
http://www.compperformancegroupstore...ct_Code=438000
i think it holds more too?
2001 F150 5.4 ext. cab 4X4, 6" RCD susp. lift, PA body lift, 35" Nitto Mudgrapplers, Superchips Tuner, 3.55 gears
Old 01-08-2009, 07:47 PM
phil, does the cooler you have, have the fluid bypass line in it?
or is that necessary?
Old 01-08-2009, 09:45 PM
Vehicle: 1997 Ford F150
Send a message via AIM to Faster150
with my Hughes Deep sump pan stock 2 Core radiator and Hayden 1403 cooler. mine runs at 166F after several hot runs and stalls. on a 9.5" triple disc billet 3200 converter
1997 F150 175K and counting
P1SC, Full Bolt-ons, and 91 Tune with 10* Timing @9psi
est. 367hp 366tq Mustang Dyno
new times coming soon!
tuning by Neal "The Car Shop" Temple-Killeen, TX
Old 01-08-2009, 09:55 PM
Aftermarket pans are available from Ford Racing Performance Parts, TCI, ACT Automatics, B&M Racing, Bowler Performance Transmissions, Mag-Hytec, & PML Inc. A quick "google" search will turn up all your options. Then it is up to you to weigh the pros & cons of each product. Just like with leveling kits, don't just pick one because it is the cheapest. They are not all the same. They are made from different metals, have different fill capacities, some come with the proper filter, some have magnetic drain plugs, et cetera.
Old 01-09-2009, 04:39 AM
Send a message via ICQ to Klitch
http://www.derale.com/atomic-cool.html
i picked one of those for $150
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
Old 01-11-2009, 09:26 PM
Klitch,
That cooler looks exactly like the one that Troyer Performance sells.
5150
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
