F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 01-04-2009, 05:12 PM
Vehicle: 1997 ford f150
blinking o/d light
driving around town the light stays off, but if im on the highway for a while the light will turn on. my 8.8 3.55 LS clutches are going to hell. my question is can the transmission sense the clutches going bad? because this light only turned on after i changed an axle seal and realized that half of my clutches were gone in my diff because i was turning it all around trying to figure out where these metal tabs came from in my fluid.
Old 01-04-2009, 05:22 PM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman03SprCrw
OD light flashing means you have a transmission fault
Old 01-04-2009, 05:28 PM
why would it come up only after messing around with my diff.?
Old 01-04-2009, 05:29 PM
Vehicle: 1998 Ford F150 4X4
could be as simple as even having bumped the wire to the speed sensor loose
Old 01-04-2009, 06:17 PM
glc glc is offline
Vehicle: 2003 Ford F150
Get your codes read with a scanner than can read Ford transmission codes.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 01-04-2009, 07:21 PM
Vehicle: 2008 Ford F150
Dumped my Expy cause of that darn light, our tranny shop could never figure out what it was...traded it in.
Old 01-04-2009, 07:39 PM
you should have dumped your tranny shop...not the truck.....
95 lightning....not done yet
Old 01-04-2009, 07:53 PM
Quote:
In my town that shop was the best, they have been around for 30 years. It was them, an Ammco and some other franchise, the kicker was I had an extended warranty that expired 1000K miles before the light began flashing.
It turned out ok, cause if I still had it I would not have my current ride (which is 2 rides later than the expy shown below).
Back then I hung out on Ford Truck World...
Old 01-05-2009, 04:32 AM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
what year truck and 4x4 or not?
my 97 had an issue with the speedo drive gear (plastic) swelling up and spinning off the shaft.
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
Old 01-05-2009, 08:36 AM
97 4x4 4.6
Old 01-05-2009, 01:37 PM
mine started blinking on sunday so it is in the shop today will let you know what my problem was
Old 01-05-2009, 02:04 PM
same config as mine, you may have the same issue i had especially if theres no symptoms and the trans acts fine. i never got a straight answer on why the speedo drive gear swells, but it happened to me several times until i put some epoxy on the shaft and the drive gear.
Old 01-05-2009, 04:30 PM
wont have an answer till friday they called and told me to take it to the tans shop here in town to get it fixed
Old 01-05-2009, 05:18 PM
how could i tell if its happening?
Old 01-05-2009, 06:04 PM
if its just the speedo drive gear you'll eventually lose your speedo.
be best if you could get a code.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
