F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 01-04-2009, 04:25 PM
Transmission goes in all gears but . . .
doesn't move in reverse. To get the truck to move backwards I've got to remove the drive shaft.
I can physically feel the tranny shift into the gears (going from park to reverse to neutral to drive/not driving).
It moves forward but I can't get the truck to move backwards in any gear including neutral.
I'm guessing internal failure but looking for some help before towing it or replacing the tranny myself.
Old 01-04-2009, 06:42 PM
how bout some more info like what kind of truck and trans is in it.....
95 lightning....not done yet
Old 01-04-2009, 07:12 PM
2001 F150 SuperCrew 4R70W
Old 01-13-2009, 03:02 PM
Just a follow up.
Took transmission out this weekend and broke it down to see what was going on.
What I found.
I need to replace the entire planet gear set. planet gear, ring gear, shell, sun gear and bearing.
Bearing failure seems to be the culprit. Gear teeth missing caused the binding I was experiencing.
Later
Old 02-05-2009, 01:47 PM
1991 f150
i just bought an f150 1991 and this truck wont go backwards in reverse or in neutral i dont know what tranny it is or how to tell but the first part of the vin is 1FTEF14N1MNA... not sure if that helps but i need to know how to determine which trans i have,so i can to replace
Old 02-05-2009, 05:49 PM
Vehicle: 2001 FORD F150
maxxxmadus, I had the same thing happen with the same trans 2 years ago. My trans shop didn't know what caused it to happen, did yours have any ideas? It would be nice to have a reason for that particular failure, since I have read more than a couple post on here with the same problem, but no cause is ever given.
Old 02-05-2009, 11:06 PM
Vehicle: 2001 Ford F150
4.6l or 5.4l truck?
Darrin
Old 02-07-2009, 10:23 AM
I would quess its the 4r7ow, seems like there the only one with that particular problem, or atleast from what I've read here. Mine was the '01 4.6 with a 4r70w.
Old 02-08-2009, 10:05 PM
i have 1991 f1504x4 i bought a bronco fullsize 4x4 thinking the tranny matched but it didnt im told mine is a E 4 0 D and if one from a 6 cylinder f150 4x4 would work any ideas
Old 02-08-2009, 10:32 PM
sorry im told a e 4 0 d from a f150 with a 6 cylinder might work and thought s would be appreciated
Old 02-08-2009, 11:48 PM
Vehicle: 2002 Ford E350
An E4OD from a six cylinder F150 will work as long as it is from a 4x4.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
Old 02-10-2009, 11:37 AM
thanks for all your help now i have located one and ive read some thing about a bearing that fails causing the planetary gears to fail but im not sure if that was it in my case thanks alot every one
Old 02-22-2009, 09:09 PM
Vehicle: 2003 Ford F150
I have a 2003 F150 135K trans serviced every 30k at dealer. On my way home from work I backed into my parking spot, no reverse it was locked up, moved forward ok though it started in 3rd gear, went to reverse again, still locked up. If you removed the driveshaft, it would roll backwards. Had it towed to my shop and removed trans pan, full of metal chunks, not cool. New trans on the way for tues. No signs of trans starting to fail. Just what I needed...
Old 02-24-2009, 04:47 PM
kingme- ask your trans shop if they know the cause. As much as I hear of this same problem with this trans, someone should know something. At this point I would settle for a educated guess if its from a trans mechanic. From one thing I've read on this forum about the 1-2 acumualator spring breaking in the 4r70w, could this cause a mechanical afailure like this? Mine did hang-up in first and than slammed second just before this happened.
Old 02-25-2009, 01:06 AM
I talked with our trans tech at my shop on his thoughts, he said it was either torque converter starting to come apart or a bearing starting to fail. Then a piece of metal or debris went through the planetary which caused the failure. Mine gave me very little warning. The od light did flash a couple of times in the last month with epc solenoid codes but always went away. I was thinking wiring concern at the time. Then after a 20 mile ride home from work I was backing into the driveway and it locked up in reverse. It sucks bigtime you try to maintain the vehicle and try not to beat on it and it does this sh&$. I am bumming mainly because I spent the majority of my savings on an engagement ring so that leaves very little left after the trans replacement which will run apporx $2000.00 through my shop with me doing the labor. Good luck with yours it seems like just a crappy characteristic of this trans!!!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
