F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 01-02-2009, 11:45 PM
1994 transmission does not downshift
1994 transmission does not downshift, transmission was downshifting randomly while in OD at crusing speed, changed filter and added 5 quarts fluid.
now runs through the gears fine but does not down shift if accelerator is pushed to floor at crusing speed. have to brake to lower the speed then
tranny down shifts and runs through the gears fine. I overfilled tranny by half a quart. would that cause the symptoms that I am encountering?
Kevin,
Old 01-03-2009, 09:17 AM
try changine the mlp senser to the newer F5 style. it is on the driver side of the trans where the linkage hooks up. youll have to change the connector too.
95 lightning....not done yet
Old 01-03-2009, 01:38 PM
Thanks I will try it!
Old 01-12-2009, 09:09 PM
The ford guy talked me into changing the Throttle Position Sensor and that fixed my Problem.
Thanks for the input!!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
