F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 01-01-2009, 07:41 PM
Trans fluid fanishing
I have a 02 Screw 5.4, 3.55 LS diff, 4x4, not sure if the trans is a 4R100 or the 4R70W. Two weeks ago when I had the local speedy lube place change the oil they added 5 pints of trans fluid, they also said there were no noticeable leaks anywhere. I checked the fluid again today and it is not touching the dipstick. Any ideas where the fluid is going?
Old 01-01-2009, 07:58 PM
if theres no leaks its going into the transfer case.........pull the fill plug on the case and see if fluid comes out heavily......
Old 01-03-2009, 01:57 PM
That seems to be the problem. Im not very mechanical but I am assuming there is a some sort of seal between the transmission and the transfer case for the fluid to escape the transmission. Is this a costly repair? Is this an easy enough repair that any shop can do or should I go to a transmission shop or maybe the dealer?
Thanks for your help.
Old 01-03-2009, 02:01 PM
the xfer case has to come out. then the input seal replaced. i work at the dealer...i prefer the dealer. i have seen too much shotty work come out of the small shops that i dont recommend them anymore. yes there are good ones too....just not in my area. if you have a good technichan/shop you trust bring it to him.
95 lightning....not done yet
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
