Most gets spit out the overflow tube. Don't ask how i know that  Your backing up, take the four bolts out of either front or back of the pan and very very lightly loosen the last one, start drainin. Put it into something you can pour into a funnel to re use tho. You'll be alright.
99' F 150 4.6 swapped 2002 5.4 and trans.
Pacesetter lth's to Magnaflow hi-flow cats, UD pulleys w/ gatorbelt, e-fans,ac bypass pulley, 9mm wires & MSD coilpacks, K&N air intake, EDGE EVO, Stage 2 Comp Cams and ported heads, Comp Cams behive valve springs, 3inch body lift w/ 35" BFG Mud Terrains on black Cregger steal rims and Eaton Posi-Unit 3.55 gears.
