F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-28-2008, 09:36 PM
4r70w 4x4 troubles
A few weeks ago I had trouble with my tranny - lost 3rd gear. I swapped it with another one that had 62k miles on it. When I tried it out it slowly shifted into reverse, and the same through all the gears. At one point it wouldn't go anymore. It idled for a couple of minutes then caught first gear, then shifted through all the rest. On the return run it would not shift into reverse. I got back to the house and put the rear end on blocks to adjust the shifter (using the reverse light trick). Still no reverse, and the tranny is very hot. Now the wheels turn in neutral and sometimes in drive also. I also noticed that the check engine light is on and it won't accelerate past about 2100 rpms. did I forget to hook something up, miss something, or did I just get a bad tranny? Any help is greatly appreciated.
Old 12-29-2008, 04:37 AM
Vehicle: 1997 Ford F150
Send a message via ICQ to Klitch
CEL is on, get the codes, it'll help us impaired help you.
my thoughts, low oil?
theres only like 3 plugins on the outside of the trans you coulda missed. the rest are under the pan.
built and blueprinted Lightning powerplant with p&p heads, race built 4r70w by Darrin @ BC-Automotive
Avoid Rods C.A.R.S. 3929 W Clearwater Ave, Kennewick, WA. screwed me on a bad transmission "built" by State Transmission of Pasco, Wa. avoid www.Engineworldusa.com, junk import motors.
Old 01-06-2009, 11:50 PM
The shop I got the tranny from gave me a replacement after I told him what happened. I'm just about done eplacing this one. One of my friends told me that the computer needs to " read " or " recognize " the tranny. Is that true? Because the manual didn't mention anything about this. I'd like to know before I fire the truck up.
Old 01-07-2009, 04:13 AM
what year trans is going in what year truck?
theres minor electrical differences, perhaps thats what your friend is thinking of.
Old 01-13-2009, 12:47 AM
My truck is an '02, I'm not sure what year the tranny is, but the only difference is that the speed sensor plug is different. We modified the plug ( cut my old plug and attached the plug from the replacement tranny) and it worked. so far it seems to be working fine. Thanks for your input guys.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
