interesting OD problem
what your dad is experiencing is a common problem ... converter lock up issues are usually not difficult to diagnose ... when the OD light is flashing, the concern is happening at that time ... even if the dealership can not duplicate the concern, there should be codes stored in the PCM ... it will be a PO7xx code ... the dealership also has a tool called a "flight recorder" ... it hoks into the ALDL connector ... the tool records what the PCM sees ... when the trans acts up, you push a button ... it records 30 seconds prior to the button activation, and the next 30 ... then the dealership can play it back and "see" exactly what happened ... honestly, it sounds like your dad needs to find another dealership - Jack
