Thanks for the info and explanation of the switch. I finally got it out with some luck and various wrenches. tested the continuity on each pin. The 4x4 hi was working, but the 4x4 low was not. When pushing the ball in on the end of the switch, continuity is activated, but when releasing/depressing the ball it seems to catch about a half a millimeter from the end of the switch. If I play around with it, I can get it to snap back out the end. Continuity on 4x4 low pin is still broken no matter how far the ball is pushed into the switch but it seems like odd operation for the ball to catch on somthing like that, but then I also don't know how the switch determins which contact is grounded, so maybe it's normal operation. Seems like maybe it is grounding both pins at the same time, so the GEM might not know what to do with that situation. So it just doesn't do anything. Reason being, is I hacked the connector and cut the bad pin off and wired in temporary wire into the cab (dealer was closed). Didn't hook the wire up to anything yet, becuase it was 4x4 low line and I'm getting 4x4 high to engage everytime and even after I've driven it for a while. I drove home last night in 4x4 high in the fresh snow and I pulled in the driveway and engaged/disengaged a few times as expected. So I think I need a new switch.
Autoparts stores don't seem to have access to this part and it was too late in the day to call my local dealer. The part number on my switch is E6TZ-7E440-A (E6TZ7E440A). Some searching around online determined this part was replaced by 3L5Z7E440AB (SW6275) I found it online for as low as 21.43+s/h to 36ish+s/h, I'm going to wait till monday and call the dealer to see if I can get one a bit sooner and not pay s/h
