F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-27-2008, 10:00 PM
Vehicle: 2000 Ford Lightning
Mercon or Mercon V
I have a 4R100 transmission. The manual says use only Mercon ATF not Mercon V. I have read a few posts on here that said I can use Mercon V in my transmission. When I was at Autozone buying the filter, their computer said to use Mercon V. I informed the guy that my owner's manual said using Mercon V in the 4R100 will cause damage.
Can anybody verify that I can or cannot use Mercon V in my 4R100? I want to change all of the fluid tomorrow. Thanks.
Old 12-27-2008, 10:11 PM
Vehicle: 01 ford f150
Use Mercon only in the 4R100. The 4R70W takes the Mercon V. I believe the Mercon V has a different friction modifier package in the fluid composition.
Old 12-28-2008, 09:47 AM
Vehicle: 2002 Ford E350
MERCON has been discontinued. Ford changed MERCON V a few years ago to make it compatible with transmissions that used MERCON.
Autozone was right. MERCON V is now the right fluid for your 4R100.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
Old 12-28-2008, 04:23 PM
glc glc is online now
Vehicle: 2003 Ford F150
Do a complete change, including draining the torque converter, and put name brand Mercon V in.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 12-28-2008, 04:40 PM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman03SprCrw
^^ agreed GLC is on the money
FIDDY IS BACK HOME click pic!
J-mod
X Dynomax Bullets X 2 16" Efans X Custom Sub Box X Reverse Fogs
Old 12-30-2008, 01:35 PM
What Transmission Fluid?
Mercon V compatibility covers those applications where Dexron I, II and III, Mercon and Chrysler 3 and 4 are recommended. For my money and transmissions I'll use Chrysler ATF+4. ATF+4 is completely compatible with Ford transmissions and will outlast Mercon V by a factor of two. In addition, shift firmness and quality are improved and torque converter clutch shudder is eliminated.
Old 12-30-2008, 02:54 PM
I would NOT recommend you use ATF+4 unless the label specifically says it meets Mercon V specs. Some manufacturers, such as Amsoil, have a full synthetic "universal" fluid that meets both specs.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
