F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-27-2008, 11:26 AM
4R100 Tranmission leaking out breather...
I have a 2000 ford lightning. When it is at WOT it begins to leak out of the breather hole on the top of the tranny. Transmission isn't over filled. Transmission shifts fine, but coast selnoid or band is working. What else could cause it to do this. I need to rebuild the tranny? Maybe cracked case?
Old 12-29-2008, 09:50 PM
Vehicle: 1999 Ford F 150
Are you talking about the overflow tubing that starts from rubber tubing that continues to metal tube facing downward?
99' F 150 4.6 swapped 2002 5.4 and trans.
Pacesetter lth's to Magnaflow hi-flow cats, UD pulleys w/ gatorbelt, e-fans,ac bypass pulley, 9mm wires & MSD coilpacks, K&N air intake, EDGE EVO, Stage 2 Comp Cams and ported heads, Comp Cams behive valve springs, 3inch body lift w/ 35" BFG Mud Terrains on black Cregger steal rims and Eaton Posi-Unit 3.55 gears.
Old 01-05-2009, 09:15 PM
It comes out of the top of the transmission with a metal hat on top of it right beside the sensor.
Old 01-05-2009, 10:12 PM
the 2wd does not have the tube coming off the vent...it just has the hat or "jiggle cap" on the vent.
95 lightning....not done yet
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
