F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-24-2008, 02:06 PM
Angry 02 clutch prob
Today my clutch pedal lost all feeling after backing out and it won't disengage. it only did this a couple times for a few secs the other day right after we had a big snow storm and a nasty temp drop so i figured that might be it since it was pretty cold last night I left it running for another 30min and got just enough of a disengage to get it reparked. Anyone know if its just a prob with the cold or is there a bigger issue?
Old 12-24-2008, 03:00 PM
glc glc is offline
Vehicle: 2003 Ford F150
Check the fluid level. If it's low, look for leaks - if the slave is leaking, fluid will be dripping out of the bottom of the bell housing, if the master is leaking, there will be fluid under the carpet behind the clutch pedal. If no leak, bleeding the system may take care of it. If the slave is leaking, transmission removal required to replace it.
Most likely? Leaky slave.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 12-24-2008, 04:15 PM
Thanks for the info
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
