F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 12-22-2008, 07:31 PM
4x4 problem
97 super cab 4x4 w/man shift---
the 4x4 light does'nt come on and the 4 wheel won't engage
any idea's
thanks tom
Old 12-26-2008, 01:21 AM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
There is a switch on the transfer case just below the vent tube. Check the connector for corrosion. I will look up the schematics to see which wire to probe and how and get back.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 12-31-2008, 11:50 AM
JMC JMC is offline
Sorry for the delay. There should be 2 wires. One is Gray. Ground that one and see if the light turns on. This one sends a ground signal to the GEM to command 4x4. The GEM then turns on the 4x4 light and engages the front axle. If the light turns on the switch in the t-case is most likely defective. If it doesn't turn on check that wire by following it along the harness to see if it is cut. To test the switch shift into 4Lo and test both switch terminals for continuity to ground. In Lo both should have continuity. Shift into 4Hi and the gray wire terminal on the switch for continuity. if the switch works then post back for more diagnostics.
Regards
Jean Marc Chartier
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
