F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 10-07-2008, 08:37 PM
Clutch engagment point changes???
Ive noticed this odd behavior in my '01 4.2 with the M5OD. The clutch engagement point will vary at different times during the day. Usually it will engage in the middle of the pedal travel, but other times I will have to let the clutch out almost all the way before it starts engaging.
The clutch freeplay also varies...from the usual inch of freeplay, to occasionally almost none.
Its been doing this for over a year now. Its just a minor annoyance and doesnt really effect the driveability of the truck much. But id like to find out what the hell is causing it and see if I can fix it.
I had alot of trans work done about 3 years/30k miles ago which included a rebuilt trans, new clutch, and new slave cylinder. The truck still has the original clutch master cylinder. Ive looked around for leaks but dont seem to see any.
Any ideas on what to do? Thanks for the help...
Old 10-07-2008, 09:36 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
You have a leak somewhere in the hydraulic system. The most common place to look is at the slave. Pull the rubber plug on the transmission and look inside the bell housing for a leak. If you have a new style slave it will have a rubber accordion boot that can hold quite a bit of fluid before it starts to show.
Look on the floor and the firewall inside the cab for signs of oil seeping past the seals in the master cylinder.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 10-08-2008, 08:50 AM
Is it possible for the slave to go bad again in only 30k? Ive been keeping an eye on the master cylinder and the fluid level doesnt seem to be dropping.
Could it possibly just be air in the system?
Old 10-08-2008, 10:33 AM
JMC JMC is offline
You can try bleeding it but if the pedal is moving around there is a leak somewhere. It doesn't take much to move the pedal.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
