I heard that if your operating temps are over 100 degrees you are OK. I have the same problem as you and winter is around the corner. I am interested to see if it will get above 100 degrees when it is very cold out. If not I will have add the cooler bypass I bought when I ordered the cooler.
2003 F150 4x4 FX4 (White): 5.4L, Custom Tuned Gryphon Programmer, DIY Air Intake Mod, True Duel Straight Pipes With X-Pipe, Factory Tech Separator Plate, F250 SD Trans Cooler, Digital Trans Temp Gauge, Timbren Rear Suspension Enhancement System, Mag-Hytech Rear Diff Cover.
