F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 09-19-2008, 02:44 AM
94 MLP Sensor and shudder
I have recently inherited a 94 F150 with a 4.9 that I plan on using as a light-duty tow vehicle. It was running quite poorly, but the routine tune-up items seemed to have solved most of the issues (plugs, wires, cap, rotor, air filter, ISC cleaning).
I still notice a hard shift between 1 and 2, and also some shudder at fast highway speed that occurred only on one occasion. There is also a slight hesitation at times when tipping-in from a stand-still.
The ECU is also complaining that the o2 sensor is running rich, and that the MLP sensor is not at expected voltage.
I am planning on getting the tranny, tc and diff fluid flushed, but I am not sure how to proceed with the MLP sensor.
I have cleared the codes from the ecu, and after driving for 20 minutes the CEL came on. For some reason, both of these codes (173 and and 634) are present. Does it sound like I truly have a bad MLP sensor, or does it sound like I have a wiring fault?
Once the tranny issues are out of the way I'll deal with the o2 issue.
Old 09-19-2008, 07:56 AM
Vehicle: 1997 Ford F150 5.4
Ford's MLP sensors have a deserved poor reputation. I'd just replace it.
Steve
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
Old 09-19-2008, 10:21 AM
Vehicle: 2002 Ford E350
I agree, replace the MLPS.
Codes can't tell the difference between a bad sensor or bad wiring. It could be either, but in this case I'd bet that it's the MLPS. They have a high failure rate.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
Old 09-19-2008, 02:22 PM
Thanks for the advice, will do.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
