F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 09-07-2008, 12:44 PM
terrible shifting from 1st to second (97 a/t v.6)
Hello,
I sure hope someone can help me here. Being a non mechanically inclined person, this issue with my poor old F150 is killing me. I want to be able to help her, but not sure if it's worth it to spend thousands and thousands to replace the tranny. I have a 97 F150 v6 with 230,000 miles on it. For the last 2years, it shifts from a stopped or slow condition to 2nd gear VERY ROUGHLY(truck shakes and jerks) and often I have to coax her into it by letting off the gas and stepping on the gas slowly about 3-4 times before it catches smoothly. Again,..this has been going on for about 2 years now and it seems to be more pronounced when the engine is warmed up. I know if I take it to a dealer they will break the bad news to me, but if anyone else might think it could be something not as catastrophic as a complete transmission replacement, please feel free to let me know. PLEASE!!
thanks.
Old 09-09-2008, 02:22 AM
Vehicle: 1999 F150 4X4
I had a problem with my '99 V6 4X4 having a very hard/late 1-2 shift (4R70W trans) which turned out to be a broken 1-2 accumulator spring. It was a relatively easy repair costing $10 for a new spring (and $60 for new fluid as I took the opportunity to replace all my trans fluid at the same time). Search the forums for 1-2 accumulator spring and you'll find several threads on the problem. I'm not sure if this is your problem, or if your '97 has the same trans, but it might be a place to start. If you're not comfortable checking the condition of the spring yourself, I'm sure a trans shop could check it for you for not a lot of money. When I had the problem, I thought the trans was toast and was thrilled when I fixed it for so little money. I hope this helps, and good luck!
You gotta love a truck the color of dirt ...
Old 09-09-2008, 08:24 PM
WOW!!! Thanks, this could be the problem! I will head to my local mechanic and see if he can give me a quote for the labor! This could be a huge bit of good news for me! Can I ask you though what it felt lik or sounded like after a stop and return to 2nd? Always the same or worse with time?
Old 09-09-2008, 11:47 PM
I had my spring break almost 2 yrs ago when I was out off-roading on vacation. I drove the truck home (400 mi), and fixed it as soon as I got home. All I really remember about how it drove was that the motor would wind real tight (XL w/ no tach) before it would shift into 2nd, but other than that the trans operated normally.
To get to the 1-2 accumulator spring, all your mechanic has to do is to remove the trans pan, remove a large snap ring and pull out the accumulator piston and springs (there are two springs). He'll also have to replace the 5 or so qts. of trans fluid you lose removing the pan. It shouldn't cost you too much.
Please keep in mind that I'm not a trained mechanic, just a guy without a lot of money who is a good troubleshooter and good w/ tools (over 30 yrs. of owning cars and I've never taken one to a shop except for tires and smog checks)
Good Luck ... I hope this fixes your problem.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
