There is a 'safety switch' that keeps the tranny in Park unless you have your foot on the brake and only releases if you have the brakes applied. It needs the brake light voltage to know to release. There is no voltage present. You say you have brake lights working so, I would suspect the safety switch. You may have a broken or pinched wire there, which is what the other thread stated in post #2.
Or you may have a short somewhere in your brake wiring that is blowing fuses, since you indicated your wipers etc... weren't working.
