F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-18-2008, 01:06 PM
Truck Is Hesitating
98 Ford F-150, 4.6 engine.
I'm experiencing what i can only describe as hesitating issues when i accelerate while i'm parked or while driving. At times it seems like it wants to choke when i make right turns. I went to Autozone and got an error of P0300 which is random mis-fire. I have changed my spark plugs about two years ago and changed out the boots about 8 months ago. I also changed out the fuel filter around the same time i changed the spark plugs. I used to have this problem before 8 months ago when i got a P0307 message and was experiencing the same issues; which is why i changed out the boots. I wasn't having a problem until just recently.
I'm not sure what to do or check at this point. Any suggestions?
Old 06-19-2008, 07:46 AM
Vehicle: 03 4X4 5.4 SCREW
Take your coil paks off and have them checked at AutoZone.
Old 06-19-2008, 06:47 PM
Vehicle: 2008 Ford F150
Send a message via AIM to bxstang2000
How many miles do you have on your truck? Have you every replace your O2 sensors?
[SIG]
2000 Ford Mustang GT
2008 Ford F150 FX4[/SIG]
Old 06-21-2008, 07:04 PM
Quote:
Yea I would def have a mechanic check your O2 Sens. That's probably where your problem is going to be!
2008 F150 FX4
Drive a Ford/Tow a Chevy
:beers:
Old 06-23-2008, 06:00 PM
I have only 94k miles on it. I'll have the O2 sensors checked then. Thanks.
Old 06-24-2008, 01:22 PM
Quote:
ok i have a question for you... i know I am a newbie .. but what would the 02 sensor have anything to do with the trany ???...
Morris
Old 06-24-2008, 07:43 PM
Quote:
Morris
Doesn’t sound like a transmission problem. He said it hesitates while driving or parked so it sounds more engine related. If it was slipping I would say transmission. O2 sensors send the computer a voltage reading depending if the exhaust gasses are rich or lean in closed loop. Then the computer determines how much fuel to add or subtract. If the o2 sensor is worn and weak it might send a slow signal which could cause hesitation, poor fuel economy, and higher emissions. A worn O2 sensor wont always throw a code so you need to monitor the o2 sensor voltage to see how its performing.
Hope this helps
John
[SIG]
Old 06-24-2008, 10:12 PM
Hope this helps
John
ok got ya... sorry miss read that one... when I put my truck into drive it is
hesitates for a few sec before popping into drive.. going down the road runs great.. ok i do have a misfire (cops and plugs on the way).. but nothing from the trany.. I am going to change the oil and filter this weekend I am hopping that puts a stop to it..
Morris
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
