F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-13-2008, 12:09 AM
Vehicle: 2004 ford f150
Send a message via AIM to Jditta
Odd situation with Cruise control
when my cruise is on, and i attempt to hitt he brake and slow down it doesnt seem to work properly. I have to push the brake almost all the down, and before the cruise goes off the engine revs up to about 2000 rpms then the cruise goes off. any ideas??
Old 06-13-2008, 01:27 AM
Vehicle: 2005 Ford F-150
I would check all the brake lights. One of my bulbs went out on a road trip and my cruise control got really screwy. Not exactly what your explaining but close. Mine didnt rev up, but when i hit the turn signal it would shut off the cruise. Mine did the same thing with the brakes though.
My day begins when yours is about to end.
"Half the ability to get the job done is not being afraid to try. 90% of the time you wont it up any worse then it already is"
Old 06-13-2008, 01:29 AM
Vehicle: 1997 ford F150
pressure switch on the master cylinder is bad!!!!!!!!!!
this is the source of the recall, switch goes bad and leaks- (the break fluid is flammable) and conducts through the fluid, disconnect the wiring harness from the switch right away and replce switch ASAP
Old 06-13-2008, 03:30 AM
Vehicle: 2006 Ford F150
Send a message via MSN to Paralyzer
he has an 04 the recall does not apply.
Old 06-13-2008, 08:49 AM
Vehicle: 1997 Ford F150 5.4
The brake light switch is either failing, out of adjustment, or the wiring/connection is intermittent.
Quickest way to check if it's the adjustment is to see if the brake lights come on when you hit the brakes but the cruise does not disengage.
The 04 uses a two-part brake light switch. One part switches the power for the stop lamps, the other part switches the signal for the speed control and the PCM. If the second part of the switch fails, stop lamp operation will still be normal, but the speed control module and the PCM will not know the brake has been pressed. Therefore, the speed control won't disengage until you hi the redundant cutt-off and the engine will race since the computer didn't know to back off throttle control as the disengagement occurs.
Someone did a post-mortem on a failed switch on one of these forums, maybe I can find it...
Steve
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
Old 06-13-2008, 12:16 PM
Steve
Please do, that would be great. I have no idea about any of that or about ff301 said. Any idea on replacement costs for this?
Justin
Old 06-13-2008, 03:58 PM
I think it was over at FTE.
You could be back from the parts store with a $15 switch and have it replaced before I even remember where I put my reading glasses..
steve
Old 06-13-2008, 04:22 PM
steve
Haha it would probably take linger than that seeeing as I dont know where it is located. Is that pretty much the only thing that could be wrong?
Justin
Old 06-13-2008, 05:06 PM
It's on the arm of the bake pdeal.
Stick your head under the dash and take a peek. You can push the pedal with your hand and you should be able to hear it click...
Steve
Old 06-13-2008, 06:35 PM
Where is the pressure switch on the master cylinder located?
Justin
Old 06-13-2008, 08:13 PM
Anyone?
Justin
Old 06-13-2008, 08:33 PM
Quote:
Have you looked ON THE MASTER CYLINDER?
Why are you screwing around? I've already given you the guidance you need for what needs checking.....
Old 06-13-2008, 08:35 PM
Im not screwing around, I dodnt know where the master cylinder is located. I have never dealt with any of this stuff before.
Sorry if i dont understand all of this and have your knowledge.
Justin
Old 06-14-2008, 12:45 PM
glc glc is offline
Vehicle: 2003 Ford F150
It's under the hood where you check and add the brake fluid..............
Have you bothered to buy a Chilton or Haynes manual for your truck yet? That would be an excellent $20 investment and will answer a LOT of questions for you.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 06-14-2008, 06:38 PM
I have never heard of either of those.
Justin
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
