F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-10-2008, 09:03 PM
How to drop a 1998 F150 Transmission
I need to find information on how to drop an auto transmission in a 98 F150 with a 4.2 4x4 and roughly how long it will take to perform. I am worried about some of the bolts really being rusted which will increase the time. I will have it rebuilt and then I will have to reinstall it. Obviously money is a huge issue which is why I am attempting this. I do have a mid range lift in my garage that I pick up cheap. It goes up roughly 46". Thanks for the help.
Old 06-12-2008, 01:38 AM
glc glc is offline
Vehicle: 2003 Ford F150
A Chilton or Haynes manual for the truck would be the best 20 bucks you can spend.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 06-14-2008, 01:47 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Yup. Get the manual. If you are handy with a tool I would say it should take you about 5-6 hours to remove the tranny & t-case. Read the procedure and make sure that you know what you are getting into. Removing the t-case involves removing some 13mm bolts that are in a tight spot. A ratchet will not fit on all of them. You will be using a 12 point wrench and going about ¼ turn at a time. A real PITA. Expect some grief on the starter bolts too. You will need a 12mm 12 point socket or box wrench to remove the drive shafts bolts. I have a ½ drive 12 socket that I use. It is all in the leverage.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 06-16-2008, 02:39 AM
Vehicle: 1998 ford F-150
Send a message via AIM to ssj4shane
not goin to lie starter is the hardest part lol...
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
