F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 05-27-2008, 12:02 PM
Vehicle: 2003 Ford F150 FX4
Factory Tech Separator Plate Kit?
I sent an email to Factory Tech because I am interested in getting the above for my 03 F150 5.4 with the 4R70W trans. I wanted to know if they sell and ship to Canada or if they have a dealer in Canada but my email remains unanswered. Does anyone here know?
2003 F150 4x4 FX4 (White): 5.4L, Custom Tuned Gryphon Programmer, DIY Air Intake Mod, True Duel Straight Pipes With X-Pipe, Factory Tech Separator Plate, F250 SD Trans Cooler, Digital Trans Temp Gauge, Timbren Rear Suspension Enhancement System, Mag-Hytech Rear Diff Cover.
Old 05-27-2008, 03:09 PM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
talk to mike dunn, he can hook you up.
http://www.madenterprise.com/F150.htm
when you go install it, follow these instructions or else you'll get whiplash
The directions are pretty simple.
Remove the valvebody.
Remove the 2-3 accumulator cap pull the spring out, lightly bend the tabs on the cap to hold it in place inverted and then remove the 1-2 accumulator with a pair of snap ring pliers. depending on which model, year, and engine you have you may have different spring combinations. Don't worry about that. Install the supplied brown spring back into the bore then put the piston in. Now put the leftover 2-3 spring up into the bore and put the cap on. then reinstall the snapring. That is likely to be the hardest part of the whole swap because you have to hold against spring pressure to install the cap. I use my thumb, but I have had alot of practice. Now scrape off all your old valvebody gaskets. Install the new gaskets and torque all bolts to 100inch lbs.
i have mine in that way and it still shifts great while grabbing rubber at WOT
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
Old 05-28-2008, 06:08 PM
Thanks. I just sent him an email. Waiting to see what he has to say.
Old 06-04-2008, 10:42 AM
I ordered from Mike at madenterprise yesterday. I can't wait to get this thing in.
Old 06-11-2008, 10:57 AM
It came today! 7 days door to door and going through Canadian Customs as well. I am hoping to put it on next week.
Old 06-12-2008, 04:00 PM
Vehicle: 2004 FORD F150
Quote:
Originally Posted by ilovejoni View Post
A shop to Maple Story Mesos,Cheapest Maple Story Mesos,Ffxi Gil Store Welcome you!cheap Ffxi Gil sale,Ao Credits in best price for sale,Look to Buy Cheap Ao Credits,Where to buy cheap Guild Wars Gold?Buy Guild Wars Gold,Looking to buy Eq2 Plat?eq2goldsell.com is providing cheap Eq2 Plat.
What the **** is that even suppose to mean ?
Old 06-12-2008, 04:38 PM
Vehicle: 200? FORD
Quote:
if you install it the "regular" way you may get whiplash, I did that and had to go back into the trans to soften the 1-2 upshift.
Old 06-12-2008, 04:39 PM
Vehicle: 200? FORD
Quote:
times like these I wish I was a moderator so I could bring out the ban stick and whack the spamming troll
Old 06-12-2008, 05:49 PM
Quote:
I printed off the directions you put above and I am going to install it that way the first time. I am not driving a race car here so I don't need the neck snapping shifts. Thanks for all the info and I am looking forward to getting this in soon.
Old 06-12-2008, 06:35 PM
x2
sorry for showing my lack o knowledge BUT.... is this basically a shift kit ?
Old 06-13-2008, 10:47 AM
That is exactly what it is. From what I have read it has the same effect as the Troyer trans valve body but is 1/3 the price.
Old 07-07-2008, 12:12 PM
Well I put the FTSP kit on this weekend. It does shift a lot firmer and overall feels good so far. I have not had much seat time with it yet. I think the shifts from 2 to 3 may be a little too firm for my liking. It seems to shift much firmer from 2 to 3 than 1 to 2 with the installation directions above. I searched out some old threads where a few people have had this complaint already. It was suggested in one of them (by dirtydog I think) to put the inside spring from the two spring combo out of the lower portion of the 1-2 accumulator in the 2-3 accumulator. Has anyone here done this?
I will try it out as installed originally for a while longer to see if it really is going to bother me. I really am not looking forward to going back in as it took me the better part of 5 hours to do it the first time (I had never done one before and really took my time) and made one hell of a mess of the floor in the garage. Did the 2 to 3 shifts without any spring in the accumulator bother anyone else recently? I think only two people in old threads with older trucks and possibly older versions of the kit than mine said they did.
Old 07-07-2008, 12:39 PM
Vehicle: 2001 Ford F150
That isn't quite accurate. The valve body you can get from Troyer is not just a simple plate mod and accumulator spring swap like that kit is.
No offense, but that is like saying drawing is the same as a photograph. You can indeed get the basic idea across with the first, but once you have the other then you will see what you have been missing.
Also, nothing against the kit that you have for a truck. That is pretty much what it was actually designed for and it should work ok. It's a decent choice for people who are worried more about price than overall performance and shift feel.
If you don't like the 2-3 shift then putting that spring in there will definitely soften it up.
Darrin
Old 07-07-2008, 02:44 PM
No offense taken. It really wasn't a money issue. I had discovered through various research that the Troyer Valve body is a very nice piece. I was going to get one when I came across the Factory Tech stuff. FT also had a valve body that was said by several posters here and other forums to be exactly like the Troyer one. Both had rave reviews by all that have owned them. Then I saw that FT had phased out there valve body because he could get the same thing accomplished with the separator plate kit and it was cheaper. That is how I ended up with the FTSP kit.
Old 07-07-2008, 03:21 PM
I am intimately familiar with the offerings from Both Troyer and Factory tech on valve body and plate kits and can 100% guarantee you that what you will get from Troyer isn't at all exactly like the FT stuff. Now that isn't a slam on the FT stuff either. You can get some great products from FT, it's just not the same by any stretch. Different philosophies went into the design and production of these specific products.
I am curious though, did the kit that you got from Mike Dunn actually say it was a Factory Tech kit. I thought he was selling another product for those plate kits. That other product is pretty much an identical copy. What I was wondering is about the packing and documentation.
Darrin
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
