F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 05-26-2008, 10:29 PM
Question 91 F150 stuck in reverse
I have a 91 f150, 5.0 with mazda 5 speed tranny, It has been sitting for over a year, and I am once again trying to get it on the road. I had the clutch kit replaced, to find out it was a twisted shaft in the tranny, so over the last couple days, I put in a used tranny from the scrap yard. Now that it is in, with everything hooked up, it will not come out of reverse, hyd clutch is bleed, and I have good peddle, with clutch pressed, it disengages, but I cannot get it out of reverse, any advice would be greatly appreciated
Old 05-27-2008, 10:14 PM
so even with the engine off its stuck? does it move in rev with the engine on
id say first pull the top cover and check to see if its the shift linkage or the sliding collar or gear/sycro
it might just be in the top cover/linkage and you could use your top cover off your old trans good luck
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
