F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-03-2008, 07:15 PM
91 E4od kickdown
i have a 91 5.8 nite F150 how do i get my tranny to kickdown sooner? it shifts to soon and wont always kickdown when you need the power. thanks mtnk
Old 03-03-2008, 07:34 PM
Vehicle: 2002 Ford E350
It's all done by the PCM. You might be able to find an aftermarket chip that can modify the shift points.
Old 03-03-2008, 08:25 PM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
No chips that I'm aware of to change the EECIV computer to modify the shift points electronicly.
Gonna have to go inside the tranny and do valve body work.
Adrianspeeder
Old 03-03-2008, 09:58 PM
You can't change when an E4OD shifts by modifying the valve body. The trans will only shift when the PCM tells the shift solenoids to change states. You'll have to modify the software to change when an E4Od shifts.
Old 03-04-2008, 03:55 PM
Is it possible that i need to change slynoids tranny has a100k on it. and i just serviced and put shift kit in.
Old 03-04-2008, 03:56 PM
If the trans will upshift through all the gears, then the solenoids are working fine.
You didn't mention before that you just put a shift kit in. It's possible that something is wrong with that, which could screw up the shifting.
Has the truck always done this? Did it change recently? It could also be a bad sensor, maybe a throttle position sensor?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
