F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 02-22-2008, 04:52 PM
Vehicle: 1997 ford f-150
Send a message via AIM to shifty_85 Send a message via MSN to shifty_85
$90.00 dollar chage?
i called a tranny shop today and asked how much a filter/fluid chage would cost he said 90 bucks for fluid filter gasket and labor....and he said they do it the old fanison way? w/e that means he said they test drive it run the computer on it and make sure everythings good...but when i told him my tranny had never been serviced in its 130,000 mile life....he said well if its burnt ill just put the pan back on and leave it alone....i think this is a pretty good deal bc if they screw something up its on the shop....but Whats the old fanison way?? and how come he said he might not wanna do it after 130,000 miles??? Thanks for ur help
Old 02-22-2008, 05:13 PM
Vehicle: 2005 FORD F150
Quote:
They will probably drop the pan and scrape off the old gasket. Then flush with new fluid until clean, add new gasket and fill with clean fluid. Those quicki-lube places just drain and refill, usually charge the same $90 too. Doesn't sound like a bad deal. But you can DIY for less $.
______________________________________
*JBA Cat4ward Titanium Ceramic Headers
*JBA T-304 SS SIDO Catback Exhaust
*Xcal II 91 Octane Performance Tune
*K&N Hi-Flow Cone Air Filter
*4.10 Gears & Traction-Lok Limited Slip
*33" BFG All Terrain KO's over 17X8 6-135 MB Gunner 6's
*Llumar Lluma Star 35% Over Factory Rear / 80% Over Front
*Kenwood Excelon HU & 120 Gig Kenwood Music Keg
*Viper 5000 Pager Alarm System
Old 02-22-2008, 05:26 PM
Vehicle: 2000 Ford F-150
Not Good
You need to get the fluid out of the converter as well with 130,000miles on the tranny. You should wait until you have the $150 to get the tranny completely flushed otherwise you are wasting your money.
malexander52
2007 F150 Lariat 5.4L 3.73LS
Super Crew
K&N Drop In Filter
Tunes and Exhaust on the way!!!!
Old 02-22-2008, 05:37 PM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman03SprCrw
dont the older 4R70W's have reusable gaskets?
FIDDY IS BACK HOME click pic!
J-mod
X Dynomax Bullets X 2 16" Efans X Custom Sub Box X Reverse Fogs
Old 02-22-2008, 05:39 PM
He's in a 2005 though
Old 02-22-2008, 06:06 PM
1997
Quote:
His sig says 1997.
I believe there was a drain plug on the torque converters pre 2000.
That being said, my gasket was a reusable gasket on my 2000. I replaced it anyway with a new rubber gasket ($21 I think) and a filter $26.
The right shop will have a machine to pull the old fluid out.
Old 02-22-2008, 06:20 PM
Vehicle: 2003 Ford F150 FX4
If it shifts and runs fine with a 130,000 miles and having no prior service I would drop the pan yourself replace the filter and gasket (it is easy sometimes messy but easy). Check for crap in the bottom of the pan. Some fine particles are normal. Then take it in to Ford or a lube shop you trust and have a tranny flush to change out all the fluid.
2003 F150 4x4 FX4 (White): 5.4L, Custom Tuned Gryphon Programmer, DIY Air Intake Mod, True Duel Straight Pipes With X-Pipe, Factory Tech Separator Plate, F250 SD Trans Cooler, Digital Trans Temp Gauge, Timbren Rear Suspension Enhancement System, Mag-Hytech Rear Diff Cover.
Old 02-22-2008, 06:25 PM
Quote:
Originally Posted by malexander52
His sig says 1997.
Crap! You're right! I don't know where I got 2005 from then, must have been thinking of one of the other threads I read....
Old 02-22-2008, 11:49 PM
ah i know i could do this my self but 90.00 bucks and if they screw up my truck they pay for it.... yes mine has the TQ converter drain on it...the final down shift at 10MPH it feels like the tranny disenages and then slams into 1st when im brakeing normal....if i lock up the brakes or down shift the truck my self it doesnt do it....other times the RPM's will just go up then it will slide into gear nice and easy....it will slip at WOT about once every 3 months depending on how much WOT i do.. fluid lvl is fine and color is fine no burning smell... yeah ill make sure when i take it up there he drains the TQ converter too.
Old 02-23-2008, 12:09 AM
Vehicle: 1997 Ford F150 5.4
Theres not a snowball's chance that "they'll pay for it" since the transmission, by your own admission to them, was neglected and was never serviced and is now failing.
You're dreaming if you think otherwise.
Steve
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
Old 02-23-2008, 12:29 AM
ah gotcha....it wasnt neglet...i just didnt have the truck early enogh...if i had been the oringal owner it would have been chaged a long time ago. 90 bucks dont seem to bad and well there pro's at trannys. They rebuilt a tranny for my buddys camaro and they did some good work. if i did it my self itd be what like 50-70 bucks? plus a mess in the drive way... if i ever get some money i think im gonna head up there.
Old 02-23-2008, 01:32 AM
you are looking at more like 40-50 if you do it yourself
fluid can be bad without looking/smelling bad. the friction aditives in the fluid seperate out over time and with heat
J-mod
Old 02-23-2008, 05:53 AM
Vehicle: 2007 Ford F150
Ask what type of fluids they use. Semi-synthetic? Synthetic? What brand? See if they can use Royal Purple or Lucas Oil. Ask if they will be willing to use fluids that you supply and knock a little off the cost. Get a few more estimates. Check with your local Ford dealer. At this time of the year, Ford dealerships around the country are running transmission service specials for as low as $89.95. My local Ford dealership charges for labor only when I supply the materials. A full flush on my truck was only $80 for 1 hour of labor. I supplied the Royal Purple ATF.
At your present mileage, also consider changing the gear oil in your differentials (front & rear), and your transfer case. I just did all of that stuff to my Explorer @ 200,000 miles. Believe me. It's like having a brand new truck all over again.
Old 02-23-2008, 12:03 PM
what fluid should i have them use i was just thinking to use Mecrov V like it says too? i only have 2WD and i blew up the rear diff about 15,000 miles ago so thats new fluid. Yeah i was thinking about buying the fluid and filter and gasket and them just chargeing labor and seeing how much that would be. Yeah i know itd be cheaper doing it my self but these guys are pro's at trannys and ive alredy seen some of there work and its pretty good. Thanks for all your comments guys
Old 02-23-2008, 12:41 PM
Vehicle: 2004 ford E-250
yes they do pat
2004 E Series Super Duty
-Troyer Performance tuned x-cal 2
-ASP Underdrive pullies & Goodyear Gatorback Belt
-Magnaflow 2 1/4" SS, x-piped,mandrel bent dual exhaust-#14335 mufflers
WWW.TROYERPERFORMANCE.COM
2006 Honda CBR1000RR-157.2 rwhp,82.5 ft.lbs.tq
2010 Honda crf 450r's-+25,Vet A,+40A
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
