02-21-2008, 09:52 PM
Which Transmission Do I Have...
I have a 1995 F150 Eddie Bauer automatic 2x4. I think that there are two transmission options on this model. The 8th letter of my VIN is N. Can someone help me out? I need a new trans and need to know which to order. Thanks!
02-21-2008, 10:09 PM
Vehicle: 2002 Ford E350
Look at the blue tag in the driver's door opening. Under TR will be either an E or a U. E means E4OD and U means 4R70W.
02-21-2008, 10:16 PM
That tag is no longer there.
02-21-2008, 11:08 PM
Vehicle: 1997 Ford F150 5.4
Quote:
Plan B: Crawl under there and count how many bolts are on the transmission pan.
Then refer to the stickied post at the top of this forum. It has ALL the information you need in one place already.
Steve
02-21-2008, 11:10 PM
So which is which? E40D has how many and 4R70W has how many?
02-21-2008, 11:38 PM
what engine do you have that would also help deturmin
02-21-2008, 11:57 PM
5.0
02-22-2008, 02:00 AM
Vehicle: 2003 Ford F150
A 5.0 could be a E4OD or a 4R70W, the E4OD pan has 20 bolts.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
02-22-2008, 08:16 AM
As I said, count your bolts. We're not psychic and can't do it for you.
Steve
If your original owner's manual is missing, download a soft copy from
www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
02-25-2008, 08:38 PM
My pan has 14 bolts. Which is that? I was told that there is another trans called and A4 or something with an A as well.
02-25-2008, 09:17 PM
You have a 4R70W then. You may be thinking AOD, the last year that was used in the F-150 was 1993. It was not electronically controlled.
02-26-2008, 11:20 AM
You might also be thinking about the E4OD which has a 20 bolt pan.
02-26-2008, 05:33 PM
Vehicle: 13 FULLsize ole' Ford rigs
Quote:
Correct.
Adrianspeeder
'08 F250 PSD 6spd 4x2, '02 F250 PSD auto 4x4,
'97 F150 4.6L 5spd 4x4, '79 F100/250 302/351M 4spd 4x2/4x4,
'79 F150 351M C6 Dually, '74 F250 360 C6 Hiboy,
'71 F100 302 4x2 3tree, '66 F250 352 4x2 3tree,
'96 Exploder XLT Sport 4.0L, Broncos: '92 XLT 302,
'90 XLT 302, '88 XLT 302/351, '84 Lariat 351HO
'85 M-1009 (K-5 Blazer) 6.2L auto US Army Surplus
ReDEPLOYED C-17 Avionics Journeyman USAF DAFB
Display Modes
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
