You can just go to a pick and pull yard and pick up one for cheap. I think the trucks had the 31 spline axles, therefore you need a 31 spline diff. You can get these out of explorers, mountaineers, and other F150s. It is easy to identify, the tag on the rear end cover will say something like this: 8 8 3L73 if it has a 3.73 with a locking differential. If not it should say: 8 8 3 73 for a non locker.
Hope this helps
Eric
2000 F150 supercab 5.4 75mm TB, K&N CAI, black projector lights, black tails, mesh grill, 40 series flowmasters, 3.73 gear w/trac lok, drilled and slotted rotors, hawk pads, rollin' on 22s ......174K+ miles and counting......soon to come.....lightning blower swap, built bottom end, and built 4R70W.
