Quote:
Originally Posted by shaunakadub
So I just hit 30,000 miles in my 2005 4.6l, and I'm starting to think about having the tranny serviced.
Anyone know how much roughly it is to have the dealer do it?
Or, has anyone ever done the BG transmission service? How did that work and how much did it cost?
I believe the manufacturer recommendation (demand) is to do a pan drop every 30K. You can easily do this yourself with 5-6 quarts of the correct fluid. The reason the dealer or anyone else may charge as much as they do is because they still take about 45+ minutes to do the job. Your gasket is reusable so don't toss it. Change the filter while you have the pan dropped. I think I paid about $18 for the WIX brand.
This is just me but I would go to walmart and buy their brand of Mercon V and do a drain/fill yourself. Then after 1000 miles, take it to the dealer and have them flush the whole thing. I prefer full synthetic atf myself.
While tranny care is often debated on what is "necessary" vs. what is "best" according to opinion, I personally see no reason whatsoever to keep 2/3 of old fluid in there. Flushing only gets you into trouble when you put lots of miles on a rig, say 100K, never service the tranny, then go to a quick change place and have them flush it with the older "backflush" machines.
Most dealers do flushes these days and consider pan dropping "old school."
I believe it is important to do both. If any "system" has a filter, that filter needs to be changed, including a transmission filter.
