Quote:
Originally Posted by NHguy
Truck is a 2005 5.4 FX4 5.4. I went to use my 4WD today cause it's snowing.
Turned to 4High switch position while going 25 mph, and got no familiar thunk, but the "4 high" light came on. When using higher amounts of throttle I heard some banging so I backed off. Later I got stuck and had to go down to 2wd to rock myself out of a pile of snow because of noises when 4wd was engaged. Later I tried 4 low, the 4 low light came on but I think I still was in 2 high by the way the truck acted and ran. I also tried using 4 high from a start and got more bad noises which seem to be from the t-case.
I did a transfer case oil change this fall with the recommend ATF and used 4wd a couple of times but never in low traction situations.
What should I check?
I have the same problem I have a 2004 lariat with 13600 miles on it It started sat morning I put it in 4high when i got out of the garage I took off from a red light and the rear end broke loose front wheels never spun This has never happened before
I will be seeing the dealer on monday I am sure glad i bought a ford esp premiumcare warrenty before my 3 year mfg warrenty ran out in oct
