F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 09-27-2007, 12:17 PM
Vehicle: 1999 FORD F150
trannys made by mazda?
I got a 99 f150, extended cab 4x4 offroad edition with a 5 speed stick shift. I heard that mazda made the tranny for my truck. is this true?
Old 09-27-2007, 12:34 PM
Didnt Realize Sticky Had It On There By Mazda - But Why Was It Made By Mazda?
Old 09-27-2007, 12:39 PM
glc glc is offline
Vehicle: 2003 Ford F150
Ford owns a significant portion of Mazda. You will probably find quite a few other Mazda-sourced parts in your truck.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 09-27-2007, 03:31 PM
Vehicle: 2002 Ford E350
Quote:
Why not Mazda? Ford had to buy it somewhere as they don't make manual transmissions any more. They purchase all of them.
Old 09-27-2007, 04:26 PM
Vehicle: 2004 Ford F150
Yes, the 5-speed manual is from Mazda.
Most of Ford's new generation of cars are based off Mazda flatforms, such as the Fusion/Milan/MKZ off the Mazda 6 platform.
Also the Ford Edge and Lincoln crossovers are based on the Mazda 6.
The European spec Ford Focus on the Mazda 3.
Old 09-28-2007, 01:19 AM
Vehicle: 1993 ford f-150
i got a 1993 f150 with a masda 5 speed if you get the same one i got
DON'T it aint good for anything it dosent help whan you got 2.73 rearend either here is the ratios for mine
Mazda:
1st 3.90:1
2nd 2.25:1
3rd 1.46:1
4th 1.00:1
5th 0.80:1 this gear is useless unless ya drive like a jackas$
(like me )
brice
Old 09-28-2007, 01:56 PM
Vehicle: 1998 Ford F150
bricelittle,
I'm thinking my '98 Lariat SuperCab 5-sp is the same tranny as you've got in your '93. The ratios look familiar. Yeah, I'd say with a 2.73 rear end, you pretty much don't need an OD gear. But think of the flip-side: my truck with the same tranny has a 3.55 rear, and 1st gear is almost too low. From a rolling 5 mph or so, I'll almost always take off in 2nd. First gear is just out of breath too quick. I've actually considered swapping my 3.55 for a 3.08. I don't think I'd lose too much torque, and it seems like it would make it easier to drive. I drive 400 miles a week to work and back, and a higher rear end would also help out at the gas pump. With my gears, at a 70 mph cruise, I'm turning over 2300 rpm in OD. I definitely use my OD 5th, but in town 4th is plenty. It's hard to believe that Ford used to put such high-geared rears in their trucks. I seem to remember an old sales brochure for a pre-'97 F150 that, when you turned to the back to see the tow ratings of the different gears, 2.73 would flat-out say "towing not recommended" or something like that. It must have strictly been for highway use. After the '97's came out, 3.08 was the highest you could get, but the majority got 3.55's, I think. While I wouldn't want to go to a 2.73, I could probably see myself installing a 3.08 if I had any $$.
Old 09-28-2007, 02:11 PM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Yes, the M5OD-R2 used with the 300, 302, 4.2L, and 4.6L is made by Mazda. Not to be confused with the M5OD-R1 used in the ranger/explorer platform.
Ford hasn't made a manual tranny since the early 80s in trucks. Otherwise sourced it to Mazda, ZF, Borg Warner, or New Process.
Adrianspeede
Old 09-28-2007, 02:23 PM
glc glc is offline
fordman3, bricelittle has an old I6 - that's a whole different story than yours. The I6 is all low end grunt, our 4.2's and 4.6's need some revs.
I'm quite happy with my 3.55's, that's a good ratio for a 4.2 as a compromise.
Old 09-28-2007, 10:23 PM
3.55's iam thinking about one of them
as far towing with the 2.73 i hook up to the trailer that i pull behind the lawn mower and smoke the clutch
napa loves me i have put in a few clutches
Brice
Old 10-01-2007, 03:44 PM
glc glc is offline
Like we were talking about in your other thread, brice, you can have the best of both worlds with a ZF5 conversion - granny low *and* an overdrive, you can prolly just keep those 2.73's if you do that.
Old 10-01-2007, 07:33 PM
ya but that is allmost a 1000 bucks a rearend is $100-$500
Old 10-01-2007, 08:44 PM
glc glc is offline
But......isn't your tranny popping out of gear anyway? I get the impression it may be on its last legs. A good used ZF can't cost that much more than rebuilding or replacing the Mazda box.
Old 10-01-2007, 08:53 PM
Quote:
that number you gave me (i think it it was you) for the auto wreakers in ca they said 1000 bucks
for the ZF used (stingy bastard$)
Old 10-01-2007, 10:23 PM
glc glc is offline
Right - and how much do you think it will cost you to fix your Mazda box?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
