F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 09-26-2007, 09:03 PM
Odd Manual trans vibration
I recently purchased a 98 4x2 V6 with Manual Trans. I get a bit of a vibration in the Shifter when I am in 3rd and applying throttle. I have checked my U-Joints with truck in Neutral and can not feel any play (I will be pulling the drive shaft this weekend just to make sure) I have also checked the Trans mount and it doesn't seem to broken or torn. The engine seems to run fine (I don't notice a miss). I am not sure if 3rd gear is a 1 to 1 ratio with the rear end and possibly magnifying a problem in the rear end or a miss in the engine that is only noticeable in 3rd.
Sorry for the long post. Just wanted to give as much info as possible.
Old 09-26-2007, 10:14 PM
glc glc is offline
Vehicle: 2003 Ford F150
4th is 1 to 1. Mine buzzes slightly in all gears and the stick jumps around on rough roads. I dunno if this is exactly what's happening to you, but I believe this is normal.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 09-26-2007, 10:18 PM
Thanks for the reply.
This is more than a buzz. I get a buzz or slight rattle in most other gears. 3rd Gear is much more noticeable. Compared to the normal buzz I would call it a good rattle. This is on the streets city driving.
Old 09-27-2007, 12:51 AM
Vehicle: 2007 Ford F150
Hmm. That's a new one in my book. It could be the synchros, but that is just a guess.
On a side note, my stick moves around a lot when I'm driving... but it does the same thing in my Dakota, and I recall in my '99.
Still, the M5OD-R2 is a very smooth tranny to operate... probably the last of the good ones out there for trucks.
**2007 Ford F-150 Regular Cab XL, Silver Clearcoat Metallic,
5 speed manual, 4.2l V6, 8' Bed, Chrome Rims,
Work Truck Package, General Grabber AT2 tires, 4x2 Rear Wheel Drive.
Mods: Lund Interceptor Smoked Bug Shield, Custom Lund Trifecta Tonneau,
VentShade Rain Guards, Pioneer DEH-6700MP, Yaesu FT-2800M,
Firestick 1/4 2M w/Belden Coax,
Cushcraft Stainless AM/FM Radio Antenna, 4.10 Motive Gears,
ScanGauge II w/X-Gauges, Kobalt Aluminum Deep Chest ToolBox,
K&N FilterMinder. **
Old 09-27-2007, 02:16 AM
Vehicle: 1993 ford f-150
i dont know if it helps any but when i replaced my clutch you half to take off the stick and i unbolted it from the tranny and the bushings were gone that caused my stick to jump and move ALOT
Brice
1993 f150
4.9L I6
mazda 5 speed
Old 09-27-2007, 11:31 AM
Quote:
Brice
1993 f150
4.9L I6
mazda 5 speed
Hmm what bushings are you referring to? The bushings for the shift rod? I may look into that.
I still haven't ruled out a U-joint going bad. It is possible that one is just starting to stick a bit and I wouldn't be able to detect it while the drive shaft is bolted up.
Old 09-27-2007, 12:42 PM
glc glc is offline
When my u-joints went bad, it didn't cause any rattle in the gearshift - they started squeaking and chirping and caused a bit of driveline shudder. I thought it was the clutches in my limited slip.
Old 09-27-2007, 02:18 PM
mine were totaly gone google Mazda tranny for a ford breakdowns click immages
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
