F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 09-24-2007, 12:23 AM
Vehicle: 1999 Ford F150
Vibration 4.2 V6
Hi everyone,
I hope I can get an answer to my question here is the story to this title. I own a 1999 Ford F150 with a V6 4.2 the motor was seized because it blew the intake gasket and water got in the lower end of the block. Now I rebuild the motor it is running smooth but there is a vibration when press on the gas to 1100 to 1200 RPM's any other is smooth idle you can not feel the motor at all. When I removed the motor I had to pull out the torque converter but then the motor could not come out because the converter was to long did not clear the firewall and then I had to remove the bolts that hold the it to the flywheel in the air but remember I could not spin the motor at all it was stuck so once I go my hands and removed it then I put a pad that was about 4 inch thick and I droped the converter and it hit the ground but not hard I do not think can that unbalance it and that is the problem??? I also check compression on all piston and vaccum etc. and she is smooth and not codes at all. I hope some one can tell me what I can check before I go and get a converter or help me balance it. Thanks to all.
Old 09-24-2007, 11:20 AM
glc glc is offline
Vehicle: 2003 Ford F150
Why are you reposting?
Vibration 4.2 V6
If anything, you probably should have originally posted it in the V6 section.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 09-24-2007, 11:53 AM
Vibration 4.2 V6
I know that I am post this again but me think it maybe be a transmission problem I would like to see if anybody had this problem before I would like to see the input of other people and remember not everyone see this psoting on the engine and the next area I will try is what you told me the V6 4.2
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
