F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 09-22-2007, 08:46 PM
Vehicle: 2007 Ford F150
Final Drive Ratio Question
Ok you gear heads, I have a question which is not important at all however is a curiosity. Say you have two trucks running 35-inch tires and one truck has an overdrive with a .77 ratio and running 4.10 in the differential, the other has an overdrive with a .69 ratio and running 4.56 in the differential (otherwise trucks are identical). According to the math they both will run 75 mph at 2,250 rpm (ok fine the 4.56 truck runs 7 rpm's less but pretty insignificant). My question is does one have any pulling advantage over the other at that condition or is the final drive ratio all that matters and they would have identical pulling power (or maybe torque would ne a better term)?
Old 09-23-2007, 01:16 AM
glc glc is offline
Vehicle: 2003 Ford F150
Identical.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 09-24-2007, 05:47 PM
Thank you.
Old 09-25-2007, 02:25 PM
Vehicle: 1983 Ford Bronco
The only difference would be the speeds of their drivelines, which relates to vibration, wear, & strength.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
