pan probably warped
sometimes when you drop the pan to change the fluid, it is left hanging from one end which can bend the flange somewhat. The gaskets are reusable, but if the pan is even slightly warped, you'll need to replace it.
in the future, if you don't already do this, be sure to drop the pan evenly to avoid potential warp.
replace the gasket first to see if that is it. $31 at local dealer. Use a container large enough to capture most of your fluid from the pan and simply reuse it. If you don't mind sinking money into a new pan, I'd do that.
good luck
