F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 09-17-2007, 10:29 AM
Vehicle: 1998 Ford F150 4.2L
Clutch problem
I have a 1998 F150,4.2 5 with 5 speed manual tranny. I got in it this morning and my clutch pedal barely liifted off the floor ( an inch or two) when the clutch took hold. It worked fine Friday ( the last time I drove it). What could go wrong over the weedend just sitting on the driveway? I check the fluid in the clutch cylinder. It was down a couple of tablespoon. Any ideas?
Old 09-17-2007, 03:26 PM
Vehicle: 1983 Ford Bronco
It's very common for the concentric slave to blow out. Ford has produced a revised design.
Old 09-17-2007, 03:30 PM
The thing is, I don't understand how it could go bad sitting in the driveway! I was looking at it a while ago and it's worse than it was this morning, and I haven't driven it!! I called Ford garage to have it towed in.
Old 09-17-2007, 04:53 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Think of a dam breaking. Once it starts there is no stopping it.....
JMC
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 09-17-2007, 07:12 PM
Here's that TSB in a PDF.
Old 09-18-2007, 03:33 AM
glc glc is offline
Vehicle: 2003 Ford F150
My slave crapped out in EXACTLY the same way. Blew it in the driveway.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 09-18-2007, 07:20 AM
That's not good news! I'm hoping that it's the clutch master cylinder. But it still doesn't make any sense to me that it would go bad just sitting. Ford garage has the truck now,but they can't get to it untill Thur. I'll let you know what they find.
Old 09-18-2007, 12:25 PM
glc glc is offline
If you see a drip under the bell housing, it's the slave. If the master is leaking you may see fluid inside the cab. When my slave went it was obvious, I filled the reservoir and pumped the pedal, fluid was literally pissing out of the bell housing vent hole. The guy that fixed it also found the master was leaking but not THAT bad.
Advice - if it's the slave have a complete clutch replacement done - because it all has to come apart to replace the slave anyway. You can expect it to cost ya about a grand.
Old 09-18-2007, 02:30 PM
I haven't seen any leaks. Either from the slave or the master cylinder. If they have to take the trans. out I'll have them do the clutch also.
Old 09-18-2007, 11:35 PM
Vehicle: '96 5.05-speed
same thing happened in my driveway, i'm with the slave also, but you might wanna do both...good luck
Old 09-20-2007, 02:23 PM
Ford garage said the problem is my slave cylinder $665.00). I told them to replace the clutch (complete) while they had it down ($280.00 more). I'll pick it up this evening.
Old 09-20-2007, 02:48 PM
glc glc is offline
Good idea - if the slave is leaking externally you now have fluid on your clutch.
Old 09-20-2007, 07:16 PM
Got the truck back. Life is good!
Old 09-21-2007, 02:14 AM
Vehicle: 1998 ford f-150
i have the exact opposite of your problem. when i drive the truck for a while or tow a heavy load in start and stop traffic, my clutch starts to grab about an inch off the floor, and there is tons of free play with no tension at the top. and if i let it sit for abit, than it works just fine. occasionally if i let it sit, for a bit then i have to put it in first gear before i can put it in reverse without it grinding abit. i have no fluid leakage anywhere and the resevoir level is constant. so one can tell me whats going on. i was about to just break down and replace the hydrolic system, but after hearing you problem, and mine is the opposite, im thinkin it might be something in the clutch components. i thought maybe a binding throw-out bearing, or a weakening preassure plate? any ideas??
Old 09-21-2007, 03:06 AM
glc glc is offline
I occasionally get the same thing when I slip the clutch excessively. I think it's boiling the fluid. Have you had the clutch bled?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
