F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 09-13-2007, 06:27 PM
Vehicle: 2005 F150
Leaking tranny lines
I've been swamped with moving and haven't had much time to get this fixed. This is on a 00 4.6 with no cooler. The lines right behind the radiator are leaking. Excuse my ignorance, what's the easiest fix, replacing the lines?
If a hammer won't fix it you got an electrical problem.
Old 09-13-2007, 07:26 PM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
Is it just the rubber section leaking?
Old 09-13-2007, 08:04 PM
Vehicle: 2005 F150
Exactly, just came in from cleaning it up and the leak is on the flexible side of the connection. I've never had to change lines like this, how are they connected? Guessing I'll just need a new flex line and I'm set?
Old 09-13-2007, 08:07 PM
Vehicle: 2007 Ford F150
Quote:
Did you try tightening the clamps? if the rubber is in bad shape and you plan to keep the truck get them replaced as soon as possible. You really don't want to starve your tranny if the ATF is low due to a leak.
Old 09-13-2007, 09:08 PM
Vehicle: 2005 F150
Quote:
The rubber sections look to have crimped connectors where the rubber overlaps the line, I don't think I can tighten them. I did some searchin and found a thread suggesting rubber or neoprene lines and clamps.
Old 09-13-2007, 10:29 PM
Cut those crimps off with a cutoff tool. Be gentle don't get into the steel line. Ford is usually good about having a flare already. Go get some transmission hose (don't use fuel line it must be transmission) and some good hose clamps ( I suggest the wide stainless steel ones from home depot).
Alan
Old 09-14-2007, 08:14 PM
Vehicle: 2005 F150
Well it's not the rubber hose. It's one of the metal lines that run parallel under the radiator. The rust is horrible and the fluid is finding its way through it. Now it looks like I need to replace that whole line. Dammit, had plans to move a few loads with it this weekend, but until it's fixed I'm down to one truck.
Old 09-14-2007, 08:16 PM
Get a good line bender, it won't cost much but it takes a while.
Alan
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
