F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 09-02-2007, 11:38 PM
Vehicle: 1992 Ford F150
Need Help! 92 f150 will not go into Second!!
like the title says my tranny will not go into second gear!
the tranny is an AOD
story
i had to replace the rear main engine seal (leaking bad) well when i got it together again the truck will go into drive but wont shift into second gear
so i can go 40 km/h and hear the tranny whine like crazy...
oh and my truck still leaks hardcore so if anyone can also help with that that would be great!
thanks!
Old 09-03-2007, 01:23 AM
Vehicle: 1983 Ford Bronco
You haven't given us NEARLY enough info to help you. Does it go into 1st or 3rd or OD? Did you drop the trans or pull the engine to do the rear main? Did you follow a shop manual? Which one? What's leaking? Where is it leaking from? Did you put thread sealer on the flexplate bolts?
Read this caption:
Old 09-03-2007, 05:44 AM
[quote=Steve83]You haven't given us NEARLY enough info to help you. Does it go into 1st or 3rd or OD? Did you drop the trans or pull the engine to do the rear main? Did you follow a shop manual? Which one? What's leaking? Where is it leaking from? Did you put thread sealer on the flexplate bolts?
it only goes into 1st it wont shift past that
dropped the t case and trans (4x4)
yes to shop manual
hanyes
dunno whats leaking its oil so
no on the sealers on the flex plates.... never said to....
Old 09-03-2007, 11:15 AM
Did you leave the torque converter on the engine when you pulled the trans? Did you put it back onto the flexplate before installing the trans? Did you refill the trans fluid & check the level after the engine was warmed up?
Old 09-03-2007, 12:41 PM
Quote:
no i did not leave the TC on the engine
no i didnt put it on the flex plate b4 installing the trans
i did refill the trans fluid level after the engine warmed up
i also shifted the gears to get fluid into all the gears and such....
Old 09-03-2007, 01:34 PM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
You shouldn't need thread sealer on the flexplate bolts, I don't think those cranks were drilled all the way through. Only vehicle I can remember having those problems were escorts and tempo's. I assume this is an aod transmission? Aod's had a roller clutch for second gear just like the early 4r70w transmissions and they were prone to failure.
Alan
Old 09-03-2007, 11:57 PM
haha u wouldnt believe it but my trucks tranny just needed adjustment
Old 09-04-2007, 12:00 AM
thanks for all the help tho! i really appreciated it
the transmission gear selector lever needed to be adjusted :P
once again thanks for the help
its nice when u come to a forum being a noob and u can get some good help
Old 09-04-2007, 12:02 AM
Vehicle: 2007 Ford F150
Quote:
What did you adjust?
Old 09-04-2007, 12:50 AM
The simple stuff can be the biggest PITA sometimes.
Glad you figured it out.
Alan
Old 09-04-2007, 01:40 AM
Good!
If your truck still has a rubber grommet for the TV cable, you should get one of these ASAP.
Quote:
Yes, the smallblock crank flanges are drilled thru.
Old 09-04-2007, 12:35 PM
That is good to know, I have never had a leak problem from one of them that way, but I usually use a little loctite which is probably sealing the threads for me.
Alan
Old 09-08-2007, 05:21 PM
so if i didnt use locktite or something like that thats where my leak could be coming from???
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
