F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 09-02-2007, 02:27 AM
Vehicle: 1998 Ford F150
transgo shift kit
i see a few of you on here running them, i was just wondering if it was worth the money for the gain that you got and what were the actual benifits of it? its not really all that expensive from what i can see and im sure i can install it, it may even be a good excuse to get under there and get the tranny fluid changed. so whatdya think?
Scott
1998 F150 SuperCab Lariat 4x4 5.4
Old 09-02-2007, 02:38 AM
I Love mine!
Old 09-02-2007, 09:37 AM
Vehicle: 1998 Ford F150 4x4 5.4L
Oh yea, awesome kit !! Firms up the shifts and puts the power to the ground - where it should be .
Also - NO slipping from the line!!! I had a slippage problem from the light. - That's eliminated ..
Couldn't brake torque before - the trans was slipping that bad - TroyerPerf sells the E4OD kit that came with hardware .. .
It's still hitting the gears great !!
Built54 and I have the E4OD's in our trucks.
Neal runs the kit , so does Klitch, look them up, they have the 4r70w's in there rides , with the kit installed and had the same great results .
I took pictures of the process - Complete tear down to the Separator Plate if you need help with it..
I've heard a few in this "trans" forum say this would ruin your transmission.
My trans has 228,000 miles on it and I installed the kit 8 months ago..
So what's that tell yuh..??
Get it
Windsor built 5.4L, E40D, Transgo kit, 9.75 Rear gear, Brembo rotors, Carquest blue's, Bilstein's, Ported & Polished Intake/TB, Pace setter LTH's, Magnaflow HFC's, Magnaflow 22X4 HF Mufler, Type 3 19lb Injectors, Volant Intake w/Amsoil EEA191 Filter, 265/17 GY Fortera's.
Old 09-02-2007, 04:19 PM
so this may sound like a bit of a silly question but ive looked before and cant really tell, how does one tell which tranny they have?
Scott
Old 09-02-2007, 04:30 PM
Quote:
Scott
Drivers door - You have two automatics that went into the 98's. Heavy duty "E" Light Duty "U"..
The "E" on the bottom line is your trans code - E = E4OD in the 98 models. However, the 99 models with the "E" code = The First 4R100 Unit..
"U" = 4R70w
Old 09-02-2007, 04:44 PM
Vehicle: 2000 Ford f1504x4
How hard is the install on them guys??I looked at Transgo's site but couldn't find anything.What is involved for the install??
Old 09-02-2007, 05:01 PM
Vehicle: 2000 Ford F150
Send a message via AIM to GreenBean00
I dont know about the Fords, but on chevys, some drilling is required, and you have to swap some springs and some small steel balls that pertain to the holding pressure of each gear. Some kits even supply you with the drill bit.
Old 09-02-2007, 05:29 PM
I wasnt going to touch my tranny, I had a performance shop put it in, the only thing I didnt do to my truck. They charged 100 to do it including oil. I hear lots of people telling me that transgo kit will screw up my tranny, but ive had it in for 40k miles and its good as the day it came off the lot.
Old 09-02-2007, 06:16 PM
It's worth every bit of $100 having someone else do it ....
First go around - it was a little to mellow hitting 2nd gear - there was a little roll to it..
The Accumulator body flow/tune plate provided in the kit adjusts piston/plunger pressure thru three holes - 1rst,2nd and third gear pressure/volume.
They give you a sheet with the most common hole sizes used for your trans model.
Like I said - those didn't work for me to mellow . Broke it all down again to adjust.
Well , I didn't want to have to do that a third time so I drilled them out 2 sizes - over sized from whats recommend..
I think Kevin will remember when I did this - 1rst gear would rev out 2nd would slam and I was getting all kinds of wheel hop
Back to the drawing board - I had to fab my own plate to reduce the holes one size smaller..
You know how much of a b^tch it was making this plate!! The holes have be perfect and the holes aren't sized for general population drill numbers - I didn't have a American size or metric that would fit those fricken holes perfectly - I had to use a reamer, rat tail file or whatever to get it tuh happen..
It worked out great after that tho..
Here's that plate -
Old 09-02-2007, 08:16 PM
Ya i remember now jbrew
I think i will pass on the shift kit!!!
Old 09-02-2007, 10:13 PM
Vehicle: 2002 F 150 ext cab
scottbigred:
Im running the transgo in my truck. i put the kit in there to firm up the shifts and shorten the lag time between shifts.
im runnin a 4.6 engine, 4r70 tranny with over 100,000 miles on the tranny when i installed the kit. from the looks of it, no one had ever dropped the tranny pan before, cause that little rubber stopper was in the pan.
i pulled a 10,000 lb trailer cross country with this setup, and the tranny is doin just fine, and i love to get on the gas and bark 2nd!!!!!
the install i done myself, using the kids little tikes picnic table as my workbench under the carport.
the only thing i can say, is if you do it yourself, dont forget to put back all the bolts in the valve body, cause i had to pull it all apart once i got the pan back on, couldnt figure on what that extra bolt was lying on the ground
this seems like a pretty good tranny kit, and relatively inexpensive. i love mine
Old 09-02-2007, 10:45 PM
You have a wimpy 4R70w - those are easy - Klitch did his while his arm was in a sling
I 'm Serious !! PM him.. - He's working on getting that lightning motor in..
He had to pull the pan again tho - like wonderboy. Klitch forgot to hook that linkage arm up
Old 09-03-2007, 02:31 AM
Vehicle: 1998 Ford F 150
The only thing I regret about my Transgo shift kit is not putting it in sooner,, I love it
Old 09-03-2007, 02:53 PM
Allright i'll ask him. I want firmer shifts!
I just can't afford to screw up my tranny!!
Old 09-03-2007, 08:07 PM
I don't know if you need one Kev - Troyers tuning your trans tablles - he better be for as long as you had to wait !!! It better do wheelies!! - Shoot that thing should slapp the wife and kick the dog for yuh by now ..
Call him, tell that's good enough , just send it .
What a tunning demand there is out there ..
Well Livernois noticed and guess what , there expanding !! About time.
Look -
High Performance Tuner Needed! Livernois Motorsports and Detroit Speed Shops are seeking an experienced aftermarket tuner for a fulltime position in their Inkster, MI facility. The location is fully equipped with state-of-the-art engine power development, machining and testing equipment, including a complete SuperFlow cylinder head development system and 901 engine dynamometer. In addition, there are 2 Mustang rear wheel dynos. The installation shop is fully equipped and staffed with technicians who will keep a talented tuner busy creating satisfied and loyal Customers. The qualified candidate will receive a base salary plus commission based upon production and could earn up to $70,000 per year. Qualifications must include: Solid basic engine mechanical and drivability diagnostic skills Excellent internal and external communication skills A strong work ethic based upon consistency and reliability Exceptional Customer focus In addition, the successful candidate must be highly proficient in working with the following hardware/software systems: SCT Products Diablo Tuners HP Tuners software LS1 Edit software Hex code A college degree is a plus, but is not required. The need to fill this position is immediate. For prompt consideration, please forward your resume to: Barbara Behler, c/o Livernois Motorsports/Detroit Speed Shops Wallis Technical Center 2850 John Daly Road Inkster, MI 48141
Damn , that job sounds fun.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
