F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-21-2007, 09:39 PM
Vehicle: 2003 Ford Lightning
Send a message via AIM to SWThomas
Cool Stainless Braided Transmission Cooler Lines Installed **PICS
I just got done swapping out my rubber lines for the SS braided set-up. It was very easy and I have to say, I love the way it looks. If anyone needs part numbers for any of this stuff, let me know...
Here's the stuff I used...
I swapped out the filter mount that came with the Summit Remote Trans Filter kit for this one. The Summit one had 1/4" ports and this one has 1/2" ports...
This is what the compression fittings that adapt the hard lines to the AN fittings looks like...
Everything went together very well and when I leak-checked all the fittings there wasn't even a hint of fluid.
2003 SVT LIGHTNING
BUILT BY JOHNNY DURHAM & ME
10.87 @ 126.52
Old 06-21-2007, 09:41 PM
2003 SVT LIGHTNING
10.87 @ 126.52
Old 06-21-2007, 09:42 PM
2003 SVT LIGHTNING
10.87 @ 126.52
Old 06-21-2007, 09:43 PM
Vehicle: 2001 ford 250
thats a nice setup.ive had tranny lines blow and leave me stranded.the frame will rust out before those lines give you any trouble lol.
Old 06-22-2007, 01:45 PM
Vehicle: 1997 Ford F150
Are you using the new filter in place of the one inside thetransmission?
or, is the new filter in addition to the one inside the transmission?
Also, please post all the part numbers.
97 F150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Live Wires & Coil Packs, Underdrive Pulleys, Troyer Performance Dual 16" Electric Fan Kit, 3.55 LS, EGR Bug Deflector, Retrax Bed Cover, BedRug, XL Full Length Running Boards,EGR Fender Flares, Air Aid Kit, Gibson Single Out Cat Back, Superchips, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks,Expedition Center Console
Old 06-22-2007, 11:10 PM
I'm using the remote filter in conjunction with the pan filter. It makes filter changes easier when I service the trans because then I don't have to drop the pan. It also filters a lot better than the pan filter does to catch the really small stuff like clutch dust. Another plus is, in case the trans decides to grenade itself the filter will catch any fragments before they enter the cooler or the return line.
I got everything from Summit...
Filter Mount 1/2" NPT Inlet/Outlet (# PRM-1211) $15.95 X1
Fitting, Straight, -6AN Male to 1/2" NPT Male, Aluminum (# RUS-670150) $7.39 X2
Hose End, Straight, -6AN (# RUS-610020) $4.88 X2
Hose End, 90 Degree, -6AN (# RUS-610160) $13.95 X2
Full Flow Hose End, 45 Degree Swivel, -6AN (# RUS-613090) $16.95 X2
Fitting, Inverted Flare, -6AN to 5/8"-18 (# RUS-640380) $4.95 X2
Adapter, Compression Fitting, -6AN to 3/8" Tubing (# RUS-639210) $8.88 X2
Hose, PROFLEX, #6-6' (# RUS 632060) $27.88 X1
For a total of $157.83
Old 06-22-2007, 11:44 PM
Vehicle: 1998 Ford F150
very nice... a want to do that eventually
Old 06-23-2007, 01:54 PM
Vehicle: 2002 Ford F-150 5.4L
Is that the stock tranny cooler??? That thing is huge!!
'02 F150 XLT 4X4 SCrew. 5.4L
K&N FIPK/Amsoil Filter
Flowmaster 40 si/do Exhaust
325/70 16 Nitto Terra Grapplers
16X10 MB Motorsport wheels
4.10 Gears
Rancho 4" lift
Edelbrock Extreme Travel Resi Shocks
Autometer Carbon Fiber Oil/Trans Temp Gauges
Carbon Fiber Interior (www.dash-kit.com)
Peterson Fluid Sys. Remote Oil Filter
FTVB
Troyer Performance Electric Fans
Underdrive Pulleys
Amsoil Fluids Throughout
My SCrew'd Garage
Old 06-23-2007, 04:37 PM
Vehicle: 2003 Ford F-150
very nice
03 F-150 5.4 FX4 with HD supercharger swap at 10PSI, 6" fabtech with PA 3" body lift, 38"15.5" MT Baja claws, on 16" 10" extreem aloys, fabtech steering stabilizer, procomp traction bars, pro comp add a leaf, cranked torsion bars,4.88 gears, detroit locker in rear, ARB locker up front, troyer E-fans, X-cal 2 tuned by Sal, FTVB shift kit, on board air system, TONS OF CUSTOM MODS, AND ONE UNSTOPPABLE BEAST
Old 06-23-2007, 07:25 PM
Quote:
Nope. It's a cooler off an F-250. I'm using it to help keep the fluid temps low because I'm running a high stall torque converter for racing.
Old 06-24-2007, 08:26 PM
Quote:
Great idea!! Bet you can pick those up for a pretty good deal?? Did it make a drastic difference in temps?? What are the dimensions on it? I've been shopping for a better cooler for towing and didn't even think of that idea.
Old 06-24-2007, 09:03 PM
You will find all the info you need here...
http://www.timskelton.com/lightning/...ranny_mods.htm
Old 06-26-2007, 06:14 PM
I'd also like to know what your tranny temps are and maybe what they use to be to compare but the setup looks sweet! Awesome job!!
Old 06-26-2007, 06:22 PM
Vehicle: 2007 Ford F150
The set up looks nice. Do you know if the set up will work for the 2007 F150
Old 06-26-2007, 08:10 PM
Quote:
I never did any datalogging or anything. I have an Auto Meter Transmission Temperature Gauge with the sender installed in a gauge port on the side of the trans. Before I did the SD Cooler, I would see temps as high as 185-190 in the summer. That would be in stop and go traffic for 30 minutes on a 90+ degree day. Since I installed the SD Cooler, I haven't seen the temps get above 155 no matter how hot it is and how long I sit in traffic. It was definitely worth all the money and work.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
