F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-20-2007, 04:55 PM
Vehicle: 1999 F150 4X4
FYI: 4R70w hard/late 1-2 shift fixed w/ $10 spring
After a recent off-road trip (8000' of very steep climbing and return), I pulled on the highway in my 99 4.2 4x4 and discovered it wouldn't shift into 2nd until very late (XL w/ no tach, but it was winding tight). All other functions of the trans operated normally. After a little research, I checked the 1-2 accumulator spring, which came out in two pieces. $10 for a new spring ($60 for new fluid as I drained the converter),the trans operates normally, and I preserve my record of having owned many vehicles in over 30 yrs. of driving and never have taken one to a shop for repair (other than for tires)! I shudder to think what a shop would charge for this repair. I hope this info helps someone else w/ a similar problem.
Old 06-20-2007, 05:20 PM
Vehicle: 2007 Ford F150
You probably saved yourself $1500. How hard was it to get to the spring?
Old 06-20-2007, 05:33 PM
To get to the 1-2 accumulator spring, all that has to be done is to remove the pan, remove a large snap ring which holds a small piston, remove the piston and the spring falls out. There are actually two springs separated by a piston ... the lower spring broke on my truck. Installing the spring was a little tricky, as you must hold the piston up to install the snap ring. I carefully pushed the piston up w/ a bottle jack in order to hold it while I installed the snap ring.
Old 06-21-2007, 12:15 AM
Do you think a late 2-3 shift would be the same prob?
Punched the gas to jump across a busy 4-lane on a Friday afternoon, let off the gas just in time to catch a very rough 1-2 shift. When I got back on the gas I had to wind my 2001 F150 up tight to get a 2-3 shift. It's been that way for a couple of weeks. Sounds like the exact same symptom only from 2 to 3. Is the 2-3 acummulator similar? I'm a tightwad and the $10 spring sounds tempting however if I go to the trouble I think I would rather drop in a Factory_Tech valve body ($225). Since I regularly pull a trailer I've been considering the valve body for a while anyway. Any words of wisdom on this?
Just found out Factory Tech no longer carries 4R70W valve bodies. Called TransGo about a shift kit; they include the 1-2 spring but not the 2-3. Real nice guy on their customer service line though, said he is hearing more and more about broken 2-3 springs.
Old 06-21-2007, 06:30 PM
Keep in mind that I know almost nothing about transmissions, but I'm a pretty good troubleshooter and I can usually take something apart and put it back together correctly. Your 2-3 shift problem sounds very similiar to the problem I had. I saw there was a 2-3 accumulator w/ springs when I was researching my problem, but I didn't pay much attention to where it was located. I think it might be under the valve body, but that's just a guess based on when I was working on my problem I didn't see anything visible under the pan that looked like the 1-2 accumulator. If I had your problem, I would certainly investgate the 2-3 accumulator springs. It's a great feeling to fix a major problem with a inexpensive part.
Old 06-23-2007, 10:48 AM
Vehicle: 2001 Ford F150
Yup, the 2-3 accumulator assembly is under the valve body. If you suspect a problem then you have to drop the VB to check that out. There is a silver cap that is held in by 3 tabs and then the spring and the accumulator. I usually remove the 2-3 spring on the stuff I see. It will shift a little harder that way, but it can get rid of a slow 2-3 shift and is better for the transmission.
I honestly have never seen a broken 2-3 spring in the several hundred of these that I have been into. I don't know where he got that from. I am thinking it is just salesman talk. I have a box of these things that I have taken out and not a one has ever been broken.
Trans-go is definitely not my favorite for the 4R70W transmissions by the way. If you are curious as to why then I would go dig around on the mustang forums and ask those guys. A lot of history.
Darrin
Old 07-09-2007, 04:55 PM
Broken 2-3 accummulator spring.
I have a broken 2-3 spring right here next to my keyboard. Installed a shiftkit while I was into the tranny. By the way, the Transgo kit does not include a 2-3 replacement spring, however the TCI kit doesn't use a return spring so I went with TCI. Please note that the teflon split-ring with the TCI kit is next to impossible to get passed the snapring groove (working against a very heavy spring). Missed the overdrive band the first time and had to tear it all down again. Also note the guy I spoke with at Transgo said he had been hearing about broken 2-3 springs lately.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
